Thread: EVR4 Build (56K Beware)
Page 3 of 10 FirstFirst 1234567 ... LastLast
Showing results 41 to 60 of 182
  1. #41
    Quote Originally Posted by Blue8G View Post
    nice! if this is up and running in time take it to MOD! in normal!
    when is it?
  2. #42
    blue8g
    September 26th
  3. #43
    12-17-2002
    Sherman Oaks, California
    4,304
    epic thread. epic build. epic car. epic.
    http://socallifestyle.com/
    1994 Galant GS 5spd
  4. #44
    September 26th
    Ill be There.
  5. #45
    blue8g
    Nice i can't wait to see this beast!
  6. #46
    i just read this whole thread an popped a nut on each page.....omg.....
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  7. #47
    This is one of the best.... no, the best build thead i have ever seen! this is mind blowing!
  8. #48
    Got my engine cover in
    Got my mirrors in should look familiar to you J-hot window shoppers LOL
    Also picked up this stereo from my friend i visit in Texas.
    JVC KD-HDR1
    And let the wiring begin LOL at LHD to RHD conversion SOOOOO never doing this again.
    I also starting making measurements for mounting my MA Audio 6X9's
  9. #49
    blue8g
    can't wait to see this!
  10. #50
    12-14-2006
    New Zealand
    823
    Umm .... I have a question for you.
    Why did you chop the front off the mirage ?
    All the parts from the evo bolt on to that car from stock. The guards and bumper support just need to be modified thats all.
    1995 FTO - V6 Mivec 200hp
  11. #51
    went from LHD to RHD
  12. #52
    12-14-2006
    New Zealand
    823
    Yes but you can still do that without cutting the front off :)
    They do that conversion here with a few american cars easily enough.
    To be honest with you I would have figured there was a much easier way to do it, you could have just swapped out everything from the evo4 cut and put it into the mirage (lancer) with much less stress and hassle. Plus the structual integrity of the car would be much better.
    Even swapping the drive from LHD to RHD would have been a snap, all you need to do is cut a hole on the other side, take the evo 4 parts off, put them into the mirage, weld up the hole for the original parts and bam you're done.... well for the most part.
  13. #53
    Quote Originally Posted by Goku View Post
    If you would of read some of my posts instead of just looking at the posts you would know why.
    My aprons were rusted all the way through in the front as well as a few structure points, Considering i needed to go RHD to fix my AC/Heat and wire harness issue i figured replacing the whole front becuase of the rust would be more sufficient.
    I actually just strengthened to weakest part of the Evo/Mirage.
  14. #54
    12-14-2006
    New Zealand
    823
    I did read that, but cutting and welding the front end is a far bigger job than repairing the rust. Plus it does make the front end weaker in the long run.
    You could have still gone RHD and fixed your other issues quite easily, just by swapping the evo parts over.
    However, I do see where you are coming from, to me there would have been a different way to go, but everyone has differnt ideas.
    In the end it will be what you want it to be, so as long as you're happy with it :D
  15. #55
    not really The pictures don't do it justice that and the prev owner spay canned it to cover the rust.
    It was just to much work, this was allot faster 2 give you any idea ive only put about 8 hours of work into this car to get it to where you see it.
  16. #56
    some pics, wiring in the interior is done besides fitting the ecu for ac stuff.
    During the extensions,
    All Done
    Closer up
    I used the factory ground adapter that was in the dash harness on the old clip becuase the evo has more grounds and it looks cleaner
    LOL don't mind this.
    My stereo harness after heat shrinking I decided to just cover the whole thing in Elec tape to make it more neat (Since there is so many wires back there)
  17. #57
    some more for you guys.
    Bottom of Driverside Rocker
    Drive shaft tunnel welded together.
    Driver side A pillar cap
    Shaved Pillar antena came out great dont have a pic grinded tho which is even better.
    Pass side Rocker cover.
    Got the dash in and wired, sadly my step moms dog chewed the f'ing wires to the Gauges :evil: :birdman:
    Chris grinding down some welds
    Chris doing some welding
    Me finishing up some welding on the opposite side
    BTW No welding gloves + Shorts = XTREME
    Quick pic
    Chris finishing up the screws on the Shifter console
    My feet lol Look at them JDM TYTE Shoes ROFL
    And last one before we called it a Night
    Had Me My Dad, Friend's, Chris, Daryl and Nick. Nick did about 95% of the welding the remaining were shared between my Dad, Chris, Daryl, and I. Started at 6AM to 11PM
    ENJOI
  18. #58
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Looking good man, keep it up i cant wait to see it when its done.
  19. #59
    only one word comes to mind....amazing
  20. #60
    blue8g
    Dang!!!!!!!!!!
