Thread: Subwoofer not working, need some help
Showing results 1 to 20 of 21
    i had just installed my sub like 2 weeks ago and it was working fine then when i installed the back speakers my sub stopped working. the fuses are all good and my back speakers work fine.
    im guessing this is the problem but im not sure. this is the ground wire i think.
    if this is the problem then what am i supposed to do with it?
    TGC Regular youngin3's Avatar
    04-02-2008
    Dallas, Texas
    642
    Does your subwoofer amp have power?
    How did they tap in a signal for the subs? Did they tap the rear speaker wires or did they plug it into the back of your aftermarket head unit?
    We need a little more info.
    the light for my amp is off so i guess thats not working. and for the wires they had to to connect it to speakers by splicing the wires.
    but they connected the wires right behind head unit.
    also i kept removing the negative battery when trying to put speakers in.
    04-01-2008
    Tempe, Arizona
    1,996
    you need to ground your amp, if thats your ground wire thats just laying around you need to bolt that down between some metal.
    yeah without ground your amp wont work
    04-10-2005
    NYC
    3,695
    from the ground wire dangling like that its posible you may have blown your amp...im sure you definately blew a few fuses at minimum
    04-01-2008
    Tempe, Arizona
    1,996
    you might of gotten lucky and had your amp go into protection mode before it blew up. But when your amp "blows up" 90% of the time it will start smoking so its hard to miss it if it did blow up
    04-02-2008
    Dallas, Texas
    642
    LMFAO!
    I was at school when I looked at this and I didn't see the pictures because of the filter.
    I almost died when I got home and saw this thread!!!
    so i could put the ground wire between a bolt like the one that holds down the chairs and tighten it down?
    04-10-2005
    NYC
    3,695
    yep
    04-10-2005
    NYC
    3,695
    make sure the car is off though when you do it
    03-12-2007
    Dallas TEXAS
    2,041
    wimp lol
    lol, thanks a lot i will do that tomorrow morning and let you guys know.
    04-02-2008
    Dallas, Texas
    642
    wimp lol
    I agree with Ricky! WIMP! It's ONLY 12 volts! :smt026
    also make sure you sand down the spot where the ground will bolt to the car, you have to get rid of any paint and be left with bare metal
    ...pain is temporary, pride is forever...
    04-02-2008
    Dallas, Texas
    642
    And don't expect your Wal-Mart Neverstart battery to hold up for very long under the abuse of a system.
    thanks a lot guys its working fine now (^_^) Now i can go blast my kicker around until it dies.
    I must admit I "lol'd" at the ground wire dangling.
    72,500 miles as of 3/30/11
    this is totally over used...
    FAIL.
    LOL
    but I guess there is a learning curve.
    HAHAHA this is kinda funny but if ur pounding a kicker right...that aint neva gonna die!!
