any constant power wire would work.just find a wire that is live when the car is off.
hey is there a wire i can plug into that will turn on a dummy light (fake alarm light) i kinda want it like how it on my mustang 5.0 when u turn the ignition off it will turn on ...so is there a wire i can tap into and itll do the same in the galant????
http://www.cardomain.com/ride/3012568 CHECK IT OUT
Sounds like your best bet would be to tap your radio's constant or run a line from the battery with a relay attached.
Use a spdt relay with the switch attached to your ignition and the relay part tapped into the constant. fuse it of course. then run your dummy light up top and you're done unless you want it to flash, in which case you just run a flasher in the mix. not difficult. If you need wiring help just ask.
you can always tap the 3rd line from the left on your black harness that goes into your speedo I am pretty sure its constant power and its right under dash so its ez enough to work the wire from there.
Post 666 :-D
Here. This is just for you. Feel special! ;)
ground is the three lines btw
ok ill try it out and see if it work lol ...i just hope i dont f shit up and blow fuse's
if it makes you feel safer, you could always disconnect the battery while you do this so it would accidentally blow a fuse during the process.
i just made its own switch....
hehehehhe my light is allllliiivvvvvvveeeee!!! lol ill post up a pic or vid of wut i did
thanks guys for the help
...and that's supposed to look like it has an alarm? lol
2017: 552whp/562wtq SBE on 19psi'02 Eclipse GT: 6G72 M/T-swapped Daily Driver'10 Endeavor: 6G75 AWD Family-mobile
I dont get it. What does that have to do with an alarm.
Looks like you got distracted when you were hooking this up... very distracted.
welcome to the galant center
wtf? ...its like the bastard child of Kit from Knight Rider and Stephen King's Christine..lol...look on the bright side..it protects you from epileptic thieves....but...i like that color blu......ack ack..face numb...eyes twit..ack....* falls to the floor and 'fries like bacon'*
I think that'd be cool as running lights as long as they didn't blink like that.
The blue color is cool looking.
lol i was going to put em on the dash top left/right corners but i thought lemme do sum diff ...i didnt know it was ganna make ppl start talkin shitt or wutnot...but hey i thought doin sum diff is better then being like the rest and copy whats already done on other rides ....im not hear to start no dramma , was just tryna share what i did
So tj is right. You got distracted lol
hmm i dont get what its supposed to be.
1996 galant s
