What else can I do?
I am riding KYB AGXs all around, with Progress springs. I have a 3G STB. camber adjusted in rear. I handle pretty well, but what else can I do to get this car to handle better and have less body roll?
Um... better/stickier tires for the handling aspect.
thick rear sway bar with poly bushings........swap the front rubber bushings for poly bushings..
sway bar.. i'll have to find one for the G.. should be pretty simple to install too
I rock a ADDCO 22mm rear sway bar. Its the ticket for sure. Super easy install, could be done with a floorjack, and two jack stands. Then you need to find a D3 Chassis Stiffening kit (not produced anymore), but Cali *MAY* produce a run of them if enough interest.
