Thread: 98 galant radiator support
Showing results 1 to 2 of 2
    Icon5 98 galant radiator support
    i was just wondering....if i have a 98 galant and i am switching out my radiator support assembly (its all twisted up), and I'm going to add a 94-96 tbar (header panel) so that i can use a bumper kit....will there be a difference in the way the parts bolt up to the radiator assembly depending on what year the radiator support assembly that i buy is?...or are the supports the same throughout all 7g galants?
    i hope i worded that properly...heh
    i just looked in my parts book, and the parts numbers for the core/radiator support are the same from 94 up to 98. so you should be all set. and from what ive read in the past. most say going from a 97/98 t bar to a 94 to 96 is just as easy as swaping it out. anyway i hope that helps and good luck.
    98 Galant ES
    Current Mods - To many to mention here.
    Future Plans - 4G63T swap and 5 speed swap
    Big Thanks To YOU ALL for all the help you provide
