Pretty sure it just clips in. I'd just slide something under it and pop it off.
anyone know how to take the chrome strip at the bottom of the window off??
i searched but it didn't bring back any results.
I just got it taped up right now while I'm sanding the door, would like to take it off so i can paint the part under it.
yup clips in, use a screw driver and go slowly.
https://www.thegalantcenter.org/show...ve+Chrome+trimI changed all my chrome door trim to black on my g so Ive had some practice. Its good your replacing the back door cus its much easier than the front. First put your window down. Then you start at one end of the trim piece and get a wide screwdriver (I wrapped it in a rag to help to keep from scratching) push up *carefuly* after one end start to come up you can pull it upward and it will snap out of the edge that holds it. then line up your new an push it down and it will pop into place.
00 Galant ES Turbo/5-Speed
13 GTR
I'd rather use a steel gasket scrapper or a specific body tool.
i'm not sure if its the front or back but it has a philips head screw holding one side
Jigz - Hit me up via PM. I can still get black DE trim for a nice price from the dealer. Rip that chrome off and get black trim. :)
Also, if you try and take off the chrome strip, go very slow and take it easy. If you bend it, even slightly, it will never look the same.
yes there is a screw in each one
