NEWBIE
Returning to stock springs, do I need new bump stops?
So unfortunately I am returning my G back to it's stock springs, so I wanted to know if I need to replace the bump stops as well? When I originally put on the Tein S-Techs we cut down the bump stops, will those still work with the stock springs or should I hit the dealership and purchase some new ones?
Any help would be great! Thanks.
Depending on the condition of the bump stops...I would just leave them as is. When you return the stock springs (and considering that your struts/shocks are in good condition) its less likely you will even bottom out on stock height unless you go over a insane bump, or uneven surface.
Personally...I think you are fine.
