Thread: Oil feed questions
Showing results 1 to 6 of 6
    Oil feed questions
    Does anybody know the measurements of the oil feed on the back of the 2.4L 4g64 block? I was running a turbo setup before i decided to sell my car. To get a good blue book value I was forced to go back to Naturally aspirated setup. In order to sell my car I am still yet to plug/block the oil feed line of the turbo that is coming from behind the block. I tried going to Home Depot to find a fitting plug with a screw pattern similar to the engines but still no luck.
    If anyone had to do this before or happen to know the measurements for the fitting, your assistance will be greatly appreciated since this is the last thing left on my "To do list."
    http://i.ebayimg.com/20/!BOhH83QCGk~$(KGrHgoH-DkEjlLly9hRBJvIeru6j!~~_1.JPG
    The smaller male side of the fitting closer to the two black screws fits perfectly besides the in the oil feed hole which is located behind my 4g64 block.
    u can buy another oil sensor for a few bucks and put it back in the block.. I believe its a bspt special adapter you wont find in home depot... The oil sensor is cheap and probably will be available faster..
    home depot has the plugs actually, its 1/8 npt
    Banned
    08-25-2005
    SLC, UT
    762
    Yeah all oil plugs on Mitsu blocks/housings are pretty much 1/8 NPT. Or it's some metric size that is close enough to 1/8 NPT that the tapered threads are able to work anyway.
    $0.90 part, good luck :)
    u can force an npt in there if ur never gonna use i would assume but i needed a bspt adapter - the npt will get tight... unless ur plugging up something attached to the back port the actual port where the sender goes into originally is 1/8 bspt..
    hehehe found 1/8 in home depot. thanks a lot guys!
Tags for this Thread
