Thread: 6G75 Question
Showing results 1 to 3 of 3
    6G75 Question
    Will parts from the 4G eclipse Mivec work on the non mivec 6G75 in the early 9G galants? Also what is the difference between the Mivec and non mivec V6?
    07-20-2003
    Orlando, FL
    3,169
    The only real difference between the MIVIC 6G75's and non MIVEC's is the MIVEC. The MIVEC heads will have cam sensors and trigger plates for the MIVEC and of course a different ECU. There are minor differences between the MIVEC and Non MIVEC heads. The block and internals are virtually identical with a difference in the pistons I believe being slightly higher compression.
    Bolt on parts should work on the Non MIVEC 6G75's from my little research I have done because my fiance's Endeavor has a 6G75.
    Banned
    08-25-2005
    SLC, UT
    762
    Blocks are the same, everything would bolt up. You could always swap in a 9G Ralliart ECU to control the MIVEC and A/T.
