Thread: How To: Fiberglass Eye Lids
Showing results 1 to 20 of 23
    Icon6 How To: Fiberglass Eye Lids
    Screwing around with some left over fiber glass material, I decided to try my best at some eye lids.
    **REMEMBER - SAFETY FIRST fiberglass and body fillers are extremely harmful. I'm not responsible for any damages done to you or your car**
    MATERIALS: Fiberglass sheets, Fiberglass Resin & Hardener, Masking tape, latex gloves, Respirator, Cooking Spray, Mixing tray & Utencil, Dremel, Body Filler
    Step 1: Clean your headlight lenses & Mask off the desired design for your lids
    Step 2: Protect your headlights. Cover the entire lens with masking tape. I chose two colors to differentiate my guide.
    Step 3: Pre-cut strips of fiberglass sheets. I used 3 layers per lens, which is pretty flexible. *This is where you want to lightly spray the masked area with cooking spray - preventing any damage to the masking tape & your lenses*
    Step 4: PUT ON YOUR MASK - Mix the fiberglass resin and hardener according to appropriate directions.
    Step 5: Apply the resin mixture onto the lens, place a strip down, brush on more mixture to the top of the strip. Repeat.
    *Remember where your guide is. This is where two colors of tape come in handy. You can go over the line, because you will cut it later*
    Once all layers are down, take any remaining resin mixture and put another whole layer over it again.
    Let it cure 1.5 - 2 hours (depending on how you made the mixture)
    Step 6: Once fully cured, draw a line on the fiber glass where your guides are. Carefully pull off the tape and the fiberglass. I slid a finger underneath one edge and inch by inch got it to lift off.
    Step 7: Cut along those guides. I found a dremel was the best way to do this.
    Starting with coarse sandpaper, sand down the eye lids to get any bumps & rough spots out. Use a 300 grit to make it extra smooth.
    Step 8: Apply Body Filler. I used a Glazing Putty, because it's very easy to apply and extremely easy to sand. Bondo will work too, yet is pretty strong. Whatever's your preference.
    It's helpful to put it back on the headlight, so make sure to put down some masking tape again to prevent any damage to your lenses.
    Give it the appropriate time to cure, then go back and carefully sand it down. Again, I worked with them on the headlights.
    Step 9: Primer & Paint to preference.
    Used a filler primer
    Viper Graphite to match the grille and pretty close to the rims.
    Test fitted - Caught it on a weird angle, they're not really lop-sided. I'll mount it when the paint cures over night
    Installed: Used 3M Double Sided Tape.
    Enjoy!
    04-01-2008
    Tempe, Arizona
    1,996
    dude thats a sick DIY. Nice Job!
    Nice tutorial! Might have to try this someday.
    07-19-2007
    Connecticut
    3,994
    Good tut man.
    awesome tut JOn!
    Jigz-TGCIL Sosick Motorsports
    Nice work man
    2001 5 speed 4g64T
    07-19-2007
    Connecticut
    3,994
    The funny thing is, I was scared to work with FG although I work with CF. So this tut will help me start somewhere with the FG. Even if it becomes a waste. Its a start.
    10-11-2003
    Schererville, IN
    666
    looks good jon. If you take a sharpie and draw your line on the tape BEFORE you lay the fiberglass, the marker line should transfer to the inside of the cured fiberglass. it may save you a little time. Keep up the good work.
    Need some paint or bodywork done in Chicagoland or NW Indiana???.. http://www.alsautobodyexperts.com/
    Thanks Eric, didn't think of that. I gotta say, the tips you've given me in the past of how to use these materials really gave me the confidence to try it out. Much appreciated
    07-19-2007
    Connecticut
    3,994
    Where can you get fiberglass?
    the auto parts store, home depot, walmart.
    07-19-2007
    Connecticut
    3,994
    Hmm never seen it there. Thanks. Just got to get a pair of heads now. I don't really want to risk using my own.
    07-19-2007
    Connecticut
    3,994
    Edit:
    nice! great idea and clean results
    Experienced TGC Member Bloody Arro's Avatar
    04-14-2009
    Highlands, Tx
    1,066
    That doesn't actually look all that hard to do.
    Nice work!
    And fwd grocery fetters are fun, you wouldn't be on this forum if you didn't agree
    Quote Originally Posted by 8thLS6 View Post
    Tuning to me is like magic... I don't understand it but it makes things happen lol
    05-03-2007
    Socal/Central Coast
    3,803
    Hm, I have about a month left of summer. I might try this out to make the car look a little more aggressive >:)
    Do it.
    now if your a little smarter youd once laying the glass on the headlight,pull it off trim it to where you want and then...POLISH THE INSIDE OF THE ARTICLE YOU JUST MADE AND LAY YOUR EYELIDS UP IN THAT.. thus you get your SMOOTH eyelids and dont need to FILL anyhting and sand anything lol.....,well thats how i do it,and then you have a mold aswell!!!!!!!
    www.qcustoms.co.nz
    05-03-2007
    Socal/Central Coast
    3,803
    But then it will be too small?
    nope....... i have sold MILLIONS of eyelids to happy clients and never once had a complaint lol,so im confident itll be fine
    www.qcustoms.co.nz
Tags for this Thread
