there is 1 10mm bolt on the bottom of the fog which holds it to the bumper. that is unless you somehow managed to have modded the stock metal bracket to fit as well although most times this is not the case.
you can reach the bolt from the underside of the car. just reach behind the bumper tward the back side of the fog light housing and you should feel it, if you cant in fact see it
to actually remove the fog light, you just pull it out from the front side of the bumper
now to fix the vapor issue, basically you want to make a series of holes so the water can evaporate much better
you will need a small drill bit.
and a drill (obviously) lol
now look around the fog itself and you will notice that there are actually 2 shields of plastic one which is behind and contains the actual reflective light and the front which is a cover. that fog which comes is just vapor which gets in between these 2 layers.
when looking around the fog housing you will notice that there are a few spots where the gap is wider and this is where you will drill your holes. in between the 2 layers.
if memory serves me right it was the 3 sides and not the bottom that had the wider gap (i may be wrong) what i did was drill 2 holes in each side for a total of 6.
after doing that there will be no more fogging since the vapor that gets caught in there has some room evaporate out much faster.
