what's your budget? what are you looking to get? what do you have in your car right now?
Damn man, I cant find shit. I'm glad you guys stop me from wasting my money though.
Budget: $150 but it would have to be a real bad ass amp. Looking for something used around $100.
Just looking for something to power my two twelves that are 200w rms 400 peak 4 ohm so something around 500w rms. I've just been hitting up craigslist all day looking for stuff and I've found a lot of junk but nothing decent.
they are single....
Yeah they are single. At first I thought they were dvc because on the back theres one line that has a colored in dot that says 4 ohm and a second line where the dot isnt colored in it says 4+4 ohms/dvc. Its just a generic sub its selenium bass 12sw2a nothing special got both of them for $20 and they both work good. I just want an amp that can deliver the most power these two can handle.
So since its 500 watts x 1 at 2 ohms you're thinking I should wire them up in a paralell to get 500w? Wouldnt that be too much?
each sub is 200 watts. 200 + 200 = 400. thus 500 will be fine
alright so would each one be getting 250w then? and what is the proper way to wire the subs to get 500w at two ohms?
both positives wires to the positive terminal of the amp.
same goes with negative
Thanks for the help, I was checking out reviews and I think I'm going to buy it. Had another question maybe you can help me with. I just got this box that holds the two twelves and its sectioned off in the middle so each sub has its own space and each section is ported on the bottom would that make a difference on how these cheap subs perform?
your subs would probably do better in a sealed box
the box was only $20 too good to pass up. i can just seal the holes. Could you answer my question about the wire kit at the bottom of page three? I really appreciate your help.
page 3? i only have 2 pages.
but some wire kits are rated for higher water due to the amount of copper in them. for instance, rockford fostgate tends to have better ratings on theirs.
Weird, this thread has 4 pages... Oh maybe you have it set to more posts show on a page than I do. I was wondering if there would be any problem mounting this under my seat and running longer speaker cable to the trunk. I know its cheap but cars get broken into left and right where I live and if the only way to get to it is by unbolting the seat I doubt its gonna get taken.
It will help me sleep better at night. Is it possible to go too thick with speaker cable? I got some heavy duty 8g laying around.
remember if you have a amp under a seat make sure it has enough room for air. amps can get pretty hot
