Your shifter linkage/cables is/are terribly messed up or you bent a shift fork...
the other day i was driving back from work on the highway then as i get off i notice that it wouldnt let me shift into 3rd or 4th gear. i tried starting the car in the morning and if my foot isnt on the clutch the car would turn off on me.also,if i do try to start the car without the foot on the clutch it jumps forward like if it was in 1st.even though its still in neutral.anyone have this problem b4?? any suggestions?
i concur .
Drive It Like You Stole It!
7G Erubini Body Kit for sale
from grinding gears
Going to agree, or if there is a rubber whaddyamacallit on the shift fork, might have worn out, and just ended up with a bit of play in it, which would throw the fork in a funny direction, if you then tried to force it, probably bend.
thanks guys....and its not common sense if u arent familiar with the transmissions and it could be a billion things
