The tires are a little tall, but should fit, and the wheel bolt pattern is the same. Though I would suggest using factory Acura/Honda ballseat lugnuts. Otherwise you risk major potential issues using non-ballseat lugnuts.
The factory Mitsubishi lugs also will NOT work. Assuming you still have the wheels in your sig those lugnuts won't seat properly either. You need to buy proper ballseat lugnuts to mount safely to your car.
You need lugnuts like the middle ones in the above picture.
