Originally Posted by
seth98esT
You dont need to do this method. To make sure that it is in time, turn the oil sprocket so the mark is at 12 o'clock, let go, if the sprocket falls towards the crank, then its in time, you can line it up with the mark and put on the belt.
If the sprocket falls clockwise, then its out of time, turn the sprocket a full turn and try again.
For the screwdriver, the bolt should be about level with the oil sprocket and a few inches in. I wouldnt mess with it, I always do the method above.
