Thread: Tips Galant 2001
Showing results 1 to 7 of 7
    Super Galant
    Tips Galant 2001
    hello friends, my Galant is 2001 and i would like to know how to find the right regulation of my engine`s belt gear.
    Valeu amigos
    I am not sure what you are asking. I know you are from Brazil, and English may not be your first language.
    What do you mean "regulation"? Please explain and we will try to help.
    01-19-2007
    Lyndhurst, NJ
    3,473
    Eu posso traduzir. Me pergunte.
    Super Galant
    Eu gostaria de saber a posição das polias na hora de trocar a correia do motor.
    Na polia da manivela tem uma marca no motor que eu ja vi aqui no site. Nas polias dos comandos eu num descobri.
    I would like to know the position of the pulleys in time to change the engine belt.
    In the crank pulley has a mark onthe engine I've seen here onthe site. Pulleys in the controls i fond a.
    I can only guess you are trying to do a timing belt / drive belts change/adjustments?
    check the following DIY
    https://www.thegalantcenter.org/showthread.php?t=16604
    03-12-2007
    Dallas TEXAS
    2,041
    interesting... . .
    Super Galant
    I would like to exchange belt time.
    Is there a topic that explains the change in engine 6a13?
    My Galant is 6 cylinders to engine 6a13
