Thread: 3.8L MIVEC Swap - Not for the faint of heart!
Showing results 21 to 40 of 41
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by PharmEcis View Post
    You would need a lot. The 4G is CAN based. Ours is obviosly OBD-II. Could you do it? Sure but then you lose tunability as the you would need a piggyback to tune the stock 4G computer.
    Ok, Im lost on the "CAN"?
    It's the successor to OBD-II. Controller Area Network. Basically everything talks to each other over a CAN bus. Think of it as a networking protocol for all the computers in the car.
    One of the problems you would face is that there is no way to drive the 8G/3G/2G instrument panel w/ the 4G ECU as it's CAN based. The ECU spits two wires out to the cluster and relays all info that way. The 8G/3G/2G have direct hookups from different sensors / senders to the cluster, many of which are eliminated in the new engine. For example, the 75 MIVEC only has one coolant temperature sensor where the 3G/3G/2G has two. One for the computer, the other for the dash.
    Greg
    '01 Stratus R/T - 5spd, 92 3000GT VR4, 03 EVO VIII, 70 Opel GT
    Owner - Ultimate Car Style & Performance www.ucsperformance.com 240.271.0280
    2007 N.A.S.A National Champions TTR Class!
    11-05-2003
    San Francisco Bay Area
    1,517
    It's already mated. F5M51, the stock 5 spd trans out of a 3G.
    Did it mate right up, or did you have to use a custom bell housing?
    04-02-2009
    Denver Colorado
    1,447
    OK...thanks for clearing that up for me. It seems there would need to be some cluster modification done as well, or some other electronics to make it work.
    Quote Originally Posted by DryBear View Post
    If I didn't mention it, it bolted right up. That includes the trans. ;)
    Greg
    04-10-2005
    NYC
    3,695
    interesting very interesting...so i assume you would be using a whole set of aftermarket gauges for monitoring then? i know you mentioned your program and screen as well...i am very curious to see how this works out.
    04-02-2009
    Denver Colorado
    1,447
    Judging from this topic posted on other sites...Pharm, you have this in the bag as they say. If anything becomes of an engine swap for me this winter I am not about to putz around with the 74...
    08-04-2003
    NY
    4,344
    That clutch/flywheel design looks just like the one from a late model nissan altima, they even use those large torx type flywheel bolts.
    Are you running an AEM EMS or an AEM FIC? If your running EMS you should be able to configure one of the outputs and scale it to properly send out a tach signal. In a worst case you can get a small 3 or 4" tach from autometer and mount it over the factory one and get the signal from the AEM (if you cant get an output signal in the factory tach's operational signal range)
    99' Galant ES
    4G64/63T
    AEM EMS
    I'm running an EMS. I'm not really worried about the tach signal, just bothered about it. There will be a PC in the dash 24/7 running AEM Pro. AEM Pro has a digital dash in it. Hell, I might even gut my cluster and just put a LCD in there running the digital dash 24/7.
    Greg
    Is it possible to fab a different dash cluster in there?
    Like an s2000 cluster or the 4g cluster? If they would be able to receive the signal.
    Sure, anything is possible. If you swapped in the 4G ECU you could technically swap in the dash and redo the wiring and your cluster could/would feasibly work.
    Again, going to a stock 4G computer is not the best idea. Once I have some time I'll start making a logic board that will allow the swap to take place on a stock computer. ;)
    Greg
    epic.
    Jigz-TGCIL Sosick Motorsports
    Challenging undertaking, but still possible. Keep us posted, I'm dying to see this in action.
    Great job so far, btw.
    2000 Mitsubishi Galant (totalled by semi, RIP)
    2000 Mitsubishi Galant - Bought off Craigslist, received organ donation from last one:
    - Engine/5spd trans/interior/suspension/brakes/etc. all moved from old car
    - 5spd | Outlander IM | StopTech BBK | Defi VSD-X HUD
    This is wonderful. Ugh i cant wait to get started on my Stratus.
    02StratusRT and 00EclipseGT
    Member Rayth's Avatar
    06-02-2008
    North Shore, Boston MA
    344
    glad that thing already came in my Galant from the factory.. much easier haha
    i wouldve assumed you'd go with a 4G eclipse 6spd transmission but glad to hear yours works fine
    01-24-2005
    DFW/Stillwater
    2,752
    first LS1 swap galant, underway
    Quote Originally Posted by Rayth View Post
    The 6spd is a shitty transmission prone to breaking at high power levels. The guts are the same as the EVO IX MR.
    Greg
    03-12-2007
    Dallas TEXAS
    2,041
    ooh snap
  19. #39
    Quote Originally Posted by lonestar22 View Post
    And what exactly does that have to do w/ this thread?
    Greg
  20. #40
    03-12-2007
    Dallas TEXAS
    2,041
    oooooooh
    well V V
