Thread: Looking for some ADVAN RS/RZ Replicas
Showing results 1 to 16 of 16
    Icon10 Looking for some ADVAN RS/RZ Replicas
    http://www.gruppe-s.com/Advan/advanrz.htm
    Hey guys I really want to find some ADVAN RS/ RZ used or replicas that look similar to these. If you guys know of any brand that has similar design please post a link to them.
    Size:18s (I want the concave aggressive look)
    My fenders are rolled and I am lowered.
    Thanks.
    04-10-2005
    NYC
    3,695
    ive seen rotas with a very similar design
    Found some!
    Would this size work?
    Rota G-Force
    Front 18 x 8.5 [5 x 114.3] Offset: +48
    Rear 18 x 9 [5 x 114.3] Offset: +30
    or
    All Four
    What size tire would I need? would a 225/40/R18 work? I think it may have to be stretched
    http://www.rotawheels.com/wheels.asp?wheelid=18
    http://www.iwsti.com/forums/gd-tires...5-concave.html
    Member Jules's Avatar
    05-19-2009
    Dortmund, GERMANY
    121
    wished they were available with 4 studs :-((((
    Quote Originally Posted by Jules View Post
    they have them up to 17x8 in the 4x 100 and 114.3
    04-10-2005
    NYC
    3,695
    Front 18 x 8.5 5 x 114.3 Offset +48
    that will work in all four corners...9.5 is way too wide
    +48 will not give that concave look tho.
    pretty sure you cant get a concave face AND not have the wheels stick out WITHOUT getting fender flares.
    its (18 x 9) lol sorry for the spacing makes it look like 9.5.
    I have 40mm right now. But I want to go lower as I said.
    Realy enoying with the EDM 4 studs :( Hard to find decent rims
    Banned
    08-25-2005
    SLC, UT
    762
    I wanted Advan RZ's for the Galant and RS's for the Evo, but then I realized it's the most played out look ever now.
    I've actually called Wheel Dude for the Rota G-Force... the only concave ones are ones with less than +35 mm offset. The rest look like shit.
    05-31-2005
    4,735
    me likey those wheels.
    Quote Originally Posted by WarmAndSCSI View Post
    The price on them aren't too bad either $900 for all four.
    Banned
    08-25-2005
    SLC, UT
    762
    Quote Originally Posted by Da_silvagride View Post
    Please read again. You cannot fit any Advan RS or RZ style wheel on your car and have it look good.
    I have severe rubbing issues on my Galant and the fenders are rolled very aggressively. I also only drive it on occasion, so it doesn't matter much. To get the Rota G-Force +30 mm 18x9 to fit, you'd have to start cutting shit.
    04-10-2005
    NYC
    3,695
    well put...
    you will have to look into some other options if you want that concaved look and that is the only size available...basically the rule of thumb is the lower the offset you want to run, the less wide the wheel would have to be...a 9"wide wheel with a 48 offset may fit ok with only roling your fenders however a 38 offset will not work at all.
    im sure there are other wheels with the same style available in a smaller width. one of my sets of wheels for example are 8.5 wide and a 36 offset. the come within about 1/4" from the ends of my fender flares. with a little negative camber they would be able to fit within the stock fenders if they are rolled well. im using this to put things in a little better perspective for you
    in all honesty for a nice aggressive wheel which will hold up it will not be all that cheap. your best bet is to find a place which will allow you to buy only 1 wheel and tire and be able to return it or exchange it for a different size if it doesnt fit
    My b bro. I missed the message. I will continue too seek out other wheels.
