Antenna
I broke my antenna when i enter the car wash and forgot to turn off the radio. Anybody know where to get the new antenna and is it hard to install it?
Thanks a lot
dealership.
and no, its not.
I am assuming that since you said you forgot to turn off your radio that you have the power antenna. I feel for you man, if you want a replacement the dealership charges about 300 big ones for a new power antenna. sure it takes about ten minutes to change but can you afford to. do what I did, 7 dollar pep boys antenna did the trick!!!!!!!!!!!!!
<div class='quotetop'>QUOTE(IllestGalant)</div><div class='quotemain'>I am assuming that since you said you forgot to turn off your radio that you have the power antenna. I feel for you man, if you want a replacement the dealership charges about 300 big ones for a new power antenna. sure it takes about ten minutes to change but can you afford to. do what I did, 7 dollar pep boys antenna did the trick!!!!!!!!!!!!!</div>
its 300 for the ENTIRE antenna.
much less for just the mast.
What do u mean by just the mast. I think the motor is still working since i still heard the motor sound when i turn on the radio.
<div class='quotetop'>QUOTE(rr)</div><div class='quotemain'>What do u mean by just the mast. I think the motor is still working since i still heard the motor sound when i turn on the radio.</div>
i mean just that.. the antenna MAST. the entire assembly includes motor, mast, and control unit.
Member
Go to Ebay and search for antenna mast. in the automotive parts section. I think I saw one there. I have bought them from EBAY and they work fine.
I have a 2nd now from ebay,
you can buy just the antenna mast from the dealer. it'll run you around $60.00. it only takes about 5 minutes to put in. i had to do mine about 6 months ago.
Heres a power antenna on eBay for $39.95, not bad
if u dont wanna pay for a new power antenna id just get a euro style on and stick it on the rear windshield and then fiberglass over the old antenna hole
Thanks guys. Now i found 2 antenna on ebay. 1 is only the mast and 1 is the full motor but i dont know which one to get. I think my motor is still working cause i still heard the sound when i turn on the radio.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...7&category=6763
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...6&category=6774
Can anybody tell me how to put the antenna mast on?
Including how to pull out the carpet until i see the motor and how to open the part on the body where i need to put the new mast on because my old broken mast is still there.
Thank you
unclesteve: please check your pm.
I will probably just do what illestgalant did. How well did it fit?
