Thread: Question
Showing results 1 to 6 of 6
    11-14-2007
    Boothwyn,PA
    719
    Question
    Ok, so i have the opportunity to pick up an entire setup to turn my 7th gen into an awd beast. I want to do the 64\63 hybrid. The question is will the 2nd gen awd gsx tranny work with the 64 block???? Does anyone know about the wire harness??? will it be plug and play?
    yes. it does.
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by skrap View Post
    what year is your galant? as if its 94-95 its better to do a 1g head swap and ecu swap like the one in the awd build thread.. 96-98 is like the 2g.. its pretty much plug and play and switching pins on the 2g ecu
    gsx tranny will work on our block but you need the corresponding front axles as well.. and you need a custom exhaust to clear the driveshaft.. o and a custom driveshaft as our wheelbase is slightly longer
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    11-14-2007
    Boothwyn,PA
    719
    Yes i know, its going to be a lot of work!!! but no one will have an awd 94 64\63 hybrid thats boosted... correct me if im wrong..... because eclipsh has the entire 4g63 in his G.
    08-13-2008
    Waterbury, CT
    3,331
    theres an awd 1994 galant GS already and im in the works of doing this in a 96
    2014 Lancer Evo GSR
    11-14-2007
    Boothwyn,PA
    719
    yea but its not the 64\63 hybrid..... thats what is different.
