This calculator should be able to answer any questions you might have about fitment. It calculates everything...even how much speed you will gain or lose!
http://www.1010tires.com/tiresizecalculator.asp
This should cut back on repeat questions about fitment. Plus you can look here if you have something other than a galant for a project car! Enjoy!
A lot of people are concerned with tires fitting without rubbing when alterations to their suspension are made (lowering, etc..)
This tire calculator does not take into consideration the largest tire you can cram up under your car; it calculates the tire that will keep the closest to stock numbers.
So this tire calculator is useful and all, I just don't see it cutting down on the questions about it.
it just gives you the difference in the speedometer reading you gonna have when you put bigger and wider wheels and tires. Thats all
also possible brake failure if you go too far. Which is a good thing. Really you should be realistic...dont try to fit the widest biggest tire with a 4" drop....thats just stupid! But I see your point...didnt think of the no account for lowered cars
