It depends........I don't know if you have a 7g or a 8g..........7g are 4 lug patterns and 8g are 5 lug patterns....
Sorry to ask AGAIN, as there are so many posts with this question, but here it goes. I found some wheels on ebay that are konig monsoon knockoffs, they are configured for a prelude though I believe. Anyways, I got this info from the seller:
The offset is 42 mm and the bolt pattern is
4x100-114.5. These are 17x7.
My question is, will these fit? Do I need more info? And if they dont fit, what would I need?
Thanks for all the help. Sorry to repeat this topic for the 100th time :oops:
2001 Galant ES I4
Injen RD CAI
Kamikaze Headers
Brospeed Prosport Muffler
Brembo X-drilled/Slotted Rotors
Progress Springs
KYB AGX Adjustables
Racing X Headlights
Smoked Tails
Custom Grill
Titanium Limo Tint
MOMO Shift Knob
Tenzo R Mean-6 18"
JBL 600.1
2 JL 12W3 D4 in topfire custom box
My ride: http://photos.yahoo.com/nrg_neo
<div class='quotetop'>QUOTE(spy)</div><div class='quotemain'>Sorry to ask AGAIN, as there are so many posts with this question, but here it goes. Â*I found some wheels on ebay that are konig monsoon knockoffs, they are configured for a prelude though I believe. Â*Anyways, I got this info from the seller:
The offset is 42 mm and the bolt pattern is Â*
4x100-114.5. These are 17x7. Â*
My question is, will these fit? Â*Do I need more info? Â*And if they dont fit, what would I need?
Thanks for all the help. Â*Sorry to repeat this topic for the 100th time Â*:oops:</div>
You say your sorry, because you know this has been asked, and answered. So, does this mean you actually didn't do a search and read the responses to the 100 other posts? I think Pinoy has answered this question in detail I don't know how many times. I think if you would have read the other post you would have an idea.
1999 2.4l
- AEM Short Ram with Blitz Sonic Air Filter
- Magnecore Wires & Denso Iridium Plugs
- Throttle Body rebored by ProFlow
- Throttle Body Coolant Bypass
- Throttle Cable adjustment
- Freedom Design Strut Bar
- Tein Springs
- KYB AGX setting 1
Exterior:
- 2nd Gen JDM Tails
- New rear 02 Molding
- Debadged Mitsubishi lettering
step 1. look at ur potential rims. count the holes. 1 2 3 4...8. its a dual lug pattern so that means 4 lugs per pattern...
step 2. walk to ur car. count the holes for ur lugs. 1 2 3 4 5
step 3. compare. will u be able to fit something that has 4 holes onto something that has 5 studs...i'll let u answer that
