Thread: oil pump
Showing results 1 to 2 of 2
    johnd
    oil pump
    will the 4g63t oil pump bolt up to the 4g64 block
    12-27-2005
    Charleston SC
    1,520
    i Swear the 7 bolt 4g63t is exactly the same. Ive seen the 7g, 1g and 2g oil pumps but the 2g looks identical.. Though im not sure it will work.
