Thread: m-rod's 99 GTZ
Page 50 of 54 FirstFirst ... 40464748495051525354 LastLast
Showing results 981 to 1,000 of 1078
  1. #981
    Very interested to see how this will turn out results wise.
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  2. #982
    Tonight the journey begins...
  3. #983
    07-02-2011
    South Florida, by the beach
    1,076
    ^yes!
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  4. #984
    New Member GTMitsu's Avatar
    11-16-2012
    Minneapolis, MN
    50
    what?
  5. #985
    What is first on the agenda, Matt? What kind of manifolds and piping will you be using?
  6. #986
    First on the agenda will be getting the 3.8 out of my garage so I have some room to work with. Then I get to drop a different engine in, so that the hot side can be built. I'll be using fed spec exhaust manifolds, but everything else will be custom designed by Justin. We're going to try something new with my setup. It should be very efficient.
  7. #987
    Awesome man! I can't wait to see what you guys come up with!
  8. #988
    11-16-2012
    Minneapolis, MN
    50
    Where is your 3.8 going? Hmmmm
  9. #989
    08-18-2004
    Charlotte, NC
    1,029
    The MN crew always doing awesome...
    1994 GS FYI
    DSM/CSM Manuals
  10. #990
    Just a little collection in the corner of my garage.
  11. #991
    But the real performance comes from that stocker strut and spring.
  12. #992
    Please let me know if you are NOT doing custom cams =) The guy that balanced my engine says he get custom cams done for me for around $800, he needs my head for maximum lift tolerance of rockers etc though.
    Can't wait to see this get done Matt!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  13. #993
    08-18-2004
    Charlotte, NC
    1,029
    That's TOO high! Should be around 350-400 dollars for regrinds.
    1994 GS FYI
    DSM/CSM Manuals
  14. #994
    Isn't regrind using and existing cam and not a blank as I'm referring to? Orrr is a regrind made from a new camshaft blank?
    I'm pretty sure he doesn't need my existing cams at all and making a completely new part.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  15. #995
    3.0, 3.5, or 3.8? Which one will it be?
  16. #996
    well I have seen 2 of them in pictures before so I'm assuming the new one is a 3.5, so 3.5!
  17. #997
  18. #998
    Going to try something different this time. I'll join a league of only a few cars that I know of that have run all 3 relevant SOHC 6G7's. This time it'll be the 6G74 with a nice little overbore and all forged internals.
  19. #999
    Next step complete. 6G74-equipped.
  20. #1000
    Pre-turbo hot side piping. Ready for fabrication.
Tags for this Thread
