Thread: wilwood big brake kit?
Showing results 1 to 5 of 5
    http://cgi.ebay.com/ebaymotors/Wilwo...ht_1344wt_1197
    just found these on ebay, this guy said it would fit a 4 lug vr4 hub
    i am assuming the vr4 and our regular 7g are the same.
    Good find! You should ask him if it comes with the brackets, otherwise these calipers are useless. Not a bad price either and it should work for galant. The estimate for evo brakes and JDM spindles is around $1000, and 3000gt brakes run for $500 for the whole setup
    but evo brakes in all all four corners(i got literally everything needed for mine for just around 800)
    That setup looks very very modified, and used.
    no way i'd pay that price knowing you'll have to get new pads and rotors and re modify them again.
    also, OP do you even have rear discs yet? cause if you don't, you might as well just get a big steel rod to jamb in your spokes every time you want to stop, cause that much front bias is going to lock up like all hell, not to mention be absolutely HORRID when it comes to vehicle dynamics when braking pre-turn in.
    John, did you get JDm spindles?
    i know this looks very modified
    so that is the reason why i ask people
    because i dont know what app he use to modified it
