Should be part of the distributor.
Taking a quick break to look through some things again, but I am off 1 tooth on the crank...1 frigging tooth! <_< craptastic
If the ignition module was faulty I wouldn't really get any spark, or a correct sequence even would I? Where is the ignition module located on the V6 then, isn't that all consolidated within the distributor assembly?
Pulled the distributor out a bit ago and found the rotor extremly hard to rotate by hand. Upon taking off the rotor, and the plate below I found some melted plastic on the bottom side that was causing the resistance. At this point I am thinking a new distributor is in order as I have checked everything else this far.
Good luck, sounds like it is a good chance it is the distributor if it looks like that.
02StratusRT and 00EclipseGT
Here are the photos of the UDP. You can clearly see where it is contacting the pulley against the timing belt cover;
Here are the photos of the distributor...tell me what you all think lol.
I ended up finding a good deal on Ebay for a distributor from a 3g eclipse with only 15K miles, only had to pay $82.50 shipped. Once the new one arrives this next week it should be the "fix" for the ongoing issue.
New distributor is installed and I still have the no start issue...what a great start to the weekend LOL.
Ivory8g and myself will be diving into this tomorrow to see if we can't find the cause for the problem. At this point everything has been checked out "ok" or been replaced with new parts...
On the power wire of the injector terminal I have 12.43-12.57 volts. When checking the signal wire I am only reading 0.01-0.02 volts of signal on all six injectors. I checked the signal voltage at the connection for the seperate bank injector harness and still have same voltage readouts.
What would be the cause of a low, or basically non-existant signal voltage?
Have you checked the MFI relay?
