your start died when you where on the highway?
Your battery or alternator took a crap.
Ok my start died on me when i was on the highway the only lights that come on was the oil, brake , and battey light and the srs what could be wrong
1996 galant s
How would you know your starter died if you are on the highway? In any event, either what he said or...Your STARTER took a crap. Either way its a bitch
ooo but what if i dont see no fuel come out of the Fuel Regulator and when i try to start it the rpm dont try to move at all.
When you try to start the car is there like a whirling sound or is the car just not turning over?
Drive It Like You Stole It!
7G Erubini Body Kit for sale
UGH wat if he broke his timing belt.
1996 galant s
and when i got that motor the dude told me the belts and everything was new
better check
cant trust no body these days
Pull off your upper timing cover check the timing belt and see if its still there.
yeah i did and it is tight on there i pull off the ower part and it is on the crank as well do you this the Crankshaft sensor..Because I check it and the wire's are still all togetter no cut or nuitting.
well im thinking about that just said f it and crapp on my ass but im see if my moms will start it because if not im start to think the ecu went out.
the sensors that lit up on you are the regular sensors that lights up when you have the key on the "on" position, so it might be the timing belt, or maybe a bad dizzy or fuel pump.
Have you tried pulling the plugs out?? or unhooking the fuel line to the rail and cranking it to see if fuel is going into the engine?
There are a lot of factors to check here.
Also make sure the T-belt is actually there. When mine went, and I checked it Tension "seemed" to be right but not until we actually pulled the covers off and pulled on the belt did it come off.
I say it is the timing belt!
well im go and take it off the covers again and take pics but i do rembemer my moms car cel come on when trying to start it but im go and look
Ok this is what happed when i se what i see [IMG][/IMG]
See that dangling belt to the left of the auto tensioner?
Time to tear off the head of your engine to see if it needs a rebuild and replace all the timing components!
timing belt went. Now hope your pistons are still intact. You'll have bent valves for sure though.
When mine snapped, one of the valves made a quarter sized hole into the piston so.... good luck to you!
