Thread: 5 speed swap question
Showing results 41 to 60 of 66
  1. #41
    Kansas City, MO
    1,244
    it takes time. took me a week and i tried all those. There are two kinds of pilot bearing removers, and yes, one of them is absolutely shitty.
    the good kind
    the shitty kind
  2. #42
    12-17-2002
    Sherman Oaks, California
    4,304
    lol @ that god damn spacer. when i first did my swap, took me about 5 minutes to pull it out. i got screwed the 2nd time though, took me almost 4 hours....
    http://socallifestyle.com/
    1994 Galant GS 5spd
  3. #43
    well the 2nd one that is what i got and i return it
    it has no effectness on our pilot bearing.
  4. #44
    ok, the devil may cry!
    i use the tool that i borrow took me like 3 bang to take that devil out
  5. #45
    Bronx NYC (reppin)
    3,489
    nice, well i ran into the spacer problem with AJ's car. took me up to 3 hrs to get the spacer off. bought the tool and it was useless.
    So far i got in the shifter, pedals,cables, flywheel, clutch, tranny lined up under the car and i am reusing front and rear A/T perches. Looks like we are in the same boat right now
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  6. #46
    well i call up the dealer and they dont know what is a perch or roll stop or i tell them what roll stop is and they said that is the mount. They have no idea what i am talking about. So what my plan is trying to reuse the perch. The good news is the top perch came with the tranny. and i test fit the front ( close to the radiator) perch fits ok and now my problem is the rear perch which it does fit on 1 bolts but not the 2 on the top so my plan is to modify it to put the bolts in, use it as temporary. but i don't know if this is going to work unless the tranny is in the car.... to be continue
  7. #47
    Bronx NYC (reppin)
    3,489
    Quote Originally Posted by kamenfaiz View Post
    Engine mount bracket
    Roll Stopper
    and our tranny didnt come with any perches at all.
  8. #48
    Bronx NYC (reppin)
    3,489
    Well finally got the tranny in, and on a side note. Unless you cut and mod the rear Perch it wont work. Looks like the front will and you need the M/T side perch also.
  9. #49
    are you reusing the speed sensor?
    mine mt tranny did not came with one
  10. #50
    12-17-2002
    4,304
    the harness for the speed sensor is the same between AT and MT, so maybe the sensor itself that bolts to the tranny is the same. try swapping the one from your AT over
    1994 Galant GS 5spd
  11. #51
    man after 3 hours
    got the tranny in
    could of gotten furthur but that mount on the top stuck me all that time
    not very hard but try to do that without making any noise at night and outside!
  12. #52
    Bronx NYC (reppin)
    3,489
    so what are u doing about the front and rear perches?
  13. #53
    the front one bolts on no problem
    it is the one close to the firewall which is the one that the sensor goes in the middle. that one sucks looks like i have to drill some holes
  14. #54
    so i am almost done here
    just need to wire it up and hook up the shifting cable
    just a question i am little confuse of which wire to which to hack to get the car start
    ps
    to bronxbombr:
    i want to get a tps for my fed 96 galant give me a price i need them
  15. #55
    bummer! install the starter and soon as i hook up the battery the starter will spin.
    is that mean bad starter or i wire something wrong?
  16. #56
    Bronx NYC (reppin)
    3,489
    I have the tps so just hit me up with a PM and a address
  17. #57
    Bronx NYC (reppin)
    3,489
    BTW, you got any pics of the auto perch on the car so i can see.
  18. #58
    i got to drill some hole on monday
    need a press drill at school
  19. #59
    Bronx NYC (reppin)
    3,489
    oh so you just gonna drill the holes in it?
  20. #60
    yeah my plan is drill 1 holes and weld another pice of metal on it to get all 3 holes correct
