6 speed? Are you counting reverse as a gear on a 3G? Did you mean 4G?
I am not that familiar with the V6 on the 8G...is it the same as on the 3G eclipse? If so how come no one has tried...or posted a 6 speed swap instead of the usual 5 speed? And if it has been posted the search didnt find it. Just curious.
I am pretty sure that it has been discussed before. Must have been on club3g though. Galant owners are not known for performance projects. Hell, I was worrying last summer that someone would beat me to second place for the 6G74 swap, and I completed it midway through this summer and still no one had gotten it done
Drive It Like You Stole It!
7G Erubini Body Kit for sale
Who in their right mind mods a Galant
Anyway, from what I understand, the 6G75 on the 4G apparently bolts up to the F5M51 (3G Eclipse manual tranny), but would need to verify that with Pharmecis. If that is the case, the 6-speed from the 4G may work on our 6G72s. I'd rather have the 6G75 tho :)
Well someone has successfully swapped in the 6G75 into a 3G eclipse and got it running. I'm pretty sure he is using the stock 3G tranny for that. IIRC, the only thing holding back others were the MIVEC heads, which he just wired to a switch on his shift knob.
but why doesn't someone just swap in the entire 6G75 + 6 speed :)
What did BJ swap...wasnt it a 6G75? I forget...that thing hauls ass thats all I do remember! LOL
no he swapped a 6G74 from a Diamante
DAH! That was it!
6g75 are 2.5L 24V Sohc motors that were used in Euro Galants and 95-00 Crysler Sebring and Dodge Avenger
Misinfo. It's a 6G73 not a 6G75 I was at the junkyard yesterday pulling apart one.
6G73
The 6G73 displaced 2497 cc. It was a 24-valve SOHC design with 2 valves running off one cam lobe, with a smaller bore than the 3.0 liter version of the same block. Bore and stroke were 83.5 mm × 76 mm (3.29 in × 2.99 in); it was a 60-degree V6 and weighed around 155 kg (340 lb). The engine had low-profile cast aluminum heads which helped it to fit into small engine bays, while pent-roof combustion chambers increased efficiency and made room for four valves per cylinder, arranged in a cross-flow pattern with a "tumble" intake port for both strong breathing and low emissions. Spark plugs were centered in the combustion chambers. The intake valves were 33 mm (1.30 in) in diameter while exhaust valves were 29 mm (1.14 in). A toothed timing belt was used.[2]
Applications
6G75
- 1995–2000 Chrysler Sebring
- 1995-2000 Dodge Avenger
- 1995–2000 Chrysler Cirrus
- 1995-2000 Dodge Stratus
- 1990–2002 Mitsubishi Diamante
- 1992–1996 Mitsubishi Galant
The 6G75 is a 3828 cc version with 95 mm (3.74 in) bore and 90 mm (3.54 in) stroke. Output varies from 172 kW (234 PS; 231 hp) and 339 N·m (250 ft·lbf) to 197 kW (268 PS; 264 hp) and 353 N·m (260 ft·lbf) depending on application. It has forged steel connecting rods.
Applications
- 2003–present Mitsubishi Pajero (aka Montero/Shogun)
- 2004–present Mitsubishi Endeavor
- 2004–present Mitsubishi Galant
- 2006–present Mitsubishi Eclipse
- 2005–2008 Mitsubishi 380
