Thread: Lowering springs
Showing results 1 to 4 of 4
    7gloverhater
    Lowering springs
    Well i am at it again...i am looking for a set of lowering springs for my 95 LS..anyone got any tips
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    That really depends on what you're after by lowering it. If you just want the look the Eibach kits aren't bad. If you want handling go with a good set of struts like Koni and some coil springs like Ground Control or a full on set of coilovers. Just remember that you get what you pay for and cheap springs and struts ride very poorly. You don't want to look like a honduh tool bouncing down the road because you put your suspension together wrong.
    dont go cheap you will regret
    07-20-2003
    Orlando, FL
    3,169
    Depends on what you are looking for in a drop..but make sure you go with a brand name company like Eibach or like Tein. Its a good idea if you go with lowering springs is to replace your struts/shocks ESPECIALLY if you are going with a drop 2" or lower. If you get springs to drop your ride around 1.5"...you can still use "stock" specs shocks/struts like KYB GR2's.
    Also if you drop a car 2" or more...you have to look to invest in a camber kit to save your tires.
