Thread: Front door check strap??
Showing results 1 to 5 of 5
    blackphantom
    So i come back from the hospital since my wife just had the baby and relized that the door wouldn't close. So i checked and found out that the thingy (check strap maybe??) was broken. Well not broken but the plastic piece had some how broke and wasn't allowing me to close the door. Now the only thing there is the metal piece that was supporting it. Meaning the metal was the support and the plastic allowed it to move by sliding back and forth when you open of close your door. Has this happen to anyone.
    01-19-2007
    Lyndhurst, NJ
    3,473
    Bad link.. But you can get them for cheap at a pick n pull junk yard.. Congrats on the newborn.
    blackphantom
    Yeah but the nearest junkyard near here is about 50 miles away. And thanks. But has this happened to anyone?
    Yes, its very common in this platform. When i bought my 00 Eclipse, both of them was broken. Then when i got the Galant my drivers side is broken.
    This website has them for $15.84
    https://www.mitsubishiparts.com/oe_parts_catalog.html
    02StratusRT and 00EclipseGT
    Here's a link to more information where you can get it. If you have a dealer close to you too, it won't be that expensive to get new.
    https://www.thegalantcenter.org/showthread.php?t=31191
