Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 1 of 53 123451151 ... LastLast
Showing results 1 to 20 of 1043
    Installed Mods
    94 Turbo FWD
    Engine
    Evo 3 Ported Intake Manifold
    60mm TB with FIAV Block off Plate
    Prothane Engine Mounts
    AFX Solid Front Motor Mount
    3g MAS+SAFC Neo
    Rear O2 Sensor Electronic Simulator
    Non-Cruise Control Throttle Cable
    Oil Catch Can /One that Actually works/
    TIAL QR BOV
    2.5'' IC piping
    Evo3 exhaust manifold
    Aluminum Gaskets
    Holset HX-35 Turbo
    TIAL External WG 20psi spring
    Evo3 O2 housing
    DOHC swap
    Slim Fans
    Wiseco pistons 9.3:1 CR
    Eagle Rods
    ACL Bearings
    SGC Racing balance shaft
    Short Route IC piping
    FP Intake pipe
    Fuel
    FIC 750cc injectors
    FIC Fuel Rail
    Fuelab 8an filter
    Aeromotive FPR
    Evo 9 fuel pump/rewired
    Exhaust
    3'' SS Downpipe
    3'' Magnaflow High Flow Cat
    CherryBomb resonator
    Dynomax Muffler
    3'' Ebay 2g GST Cat-back (extended)
    Suspension
    5lug conversion
    18mm 8g rear sway bar
    19mm front sway
    8g Rear Tubular control arms
    KYB GR2 fronts, KYB AGX rear (2g shocks /springs)
    8g VR4 Front Strut Tower bar
    Ingalls Front and Rear Camber Kits
    Protane Full Bushing Kit
    Brakes
    Evo 8 Brembo Calipers
    Evo 8 Stock Front/Rear Rotors
    Rear Disc Conversion
    SS brake lines
    Drivetrain
    5spd swap
    Galant transmission/ with LSD
    ACT Pressure Plate/Clutch
    Fidanza Flywheel
    SS Clutch Line
    Aluminum Shifter Cable Inserts
    Symborski Shifter Base kit
    Short Shifter
    Evo 9 Shift Knob
    Interior
    Tan Sprayed Carpet
    Black Leather Upholstered Door Panels
    Brand new Tan leather seats
    3g Eclipse black Front Seat Belts
    Evo Steering Wheel
    Evo Round Shifter Bezel
    ProSport Boost Gauge, Oil pressure, Digital AFR gauges
    Exterior
    8g Galant Stock Spoiler
    7g JDM DE Front Bumper Conversion
    7g JDM DE Rear Tail light Conversion
    JDM 2-piece Glass Head Lights
    '02 Lancer OZ Edition side skirts
    8g JDM fender turn signals
    Evo 8 hood vent
    Wheels And Tires
    Evo 8 Enkei
    Tires 235/45R17
    Stock Evo 8 Lug NUts
    Audio/Electronics
    Pioneer DEH 3800
    61/2'' Pioneer Front Components with Tweeters
    6x9'' Infinity Reference Rear Components
    94 GS AWD/Turbo
    Engine
    DSM LINK
    TIAL QR BOV
    2.5'' IC piping
    HAFE/BEP exhaust manifold
    TIAL MVS External WG /20psi spring
    Aluminum Gaskets
    Holset HX-35 Turbo
    Evo3 O2 housing
    Slim Fans
    ACL Bearings
    Balance shaft Delete
    FP Intake pipe
    Fuel
    RC 650cc injectors
    Fuelab 8an Filter
    Supra TT fuel pump
    Evo 9 FPR
    Exhaust
    3'' Downpipe
    Dynomax Muffler
    Suspension
    5lug conversion
    21mm front sway
    Ebay Front Strut Tower bar
    SPC Front Camber Kit
    Brakes
    05 Outlander Front Calipers/Rotors
    Early 95 Ecipse Rear calipers/ Vented Rotors
    SS brake lines
    ABS delete
    Drivetrain
    AWD swap
    96 Talon transmission/Transfer case/ Rear Diff with LSD
    Fidanza Pressure Plate
    ACT 6 puck/sprung Clutch
    Stock Flywheel
    SS Clutch Line
    Short Shifter
    Interior
    Tan Carpet
    2-toned Leather Upholstered Door Panels
    3g Steering Wheel
    Sportcomp Boost Gauge, Oil pressure, AEM Digital AFR gauges
    Exterior
    94 Galant Stock Spoiler
    Wheels And Tires
    Evo 8 Enkei
    Tires 225/45R17
    Audio/Electronics
    Alpine headunit
    Kicker front/rear speakers
    The car has been through many changes, and I have taken pictures of everything. It is my daily driver and my project, and it is really hard to modify it this way .For some it may be annoying, for some it may be fun. I hope you enjoy it!
    This is how my car looked when I first took it home back in 2006/winter/ - just another galant on the street. That didn't work out for me very well; having experience in painting and detailing cars, some basic knowledge of mechanics I can proudly say that my car hasn't been in shop for any repairs. So here we go:
    Did my first ghetto mods /hahaha/
    The "monster" 2.4L 16V SOHC engine
    During the summer I installed my first sway bar out of 2g GST /15mm/
    I did the front and rear end conversion to 97-98 Galant /7Gb/, and got my first Evo spoiler - Evo 7 actually. Started working on the enterior again
    interior
    2007 winter
    I started modding as much as i could:
    Did my rear disc swap, dual piston front calipers off 2G GSX, and 5 lug conversion to all four corners.
    2008 Spring
    I took a week off and started this.............and yes i painted it in the driveway.
    making some progress
    Finally done!!
    Installed exhaust: 1g Eclipse Tsudo SS header, 3'' Magnaflow cat and 3'' Megan catback.
    Pulled the old rear sway bar out.....
    ......and replaced it with 8G Galant 18mm sway bar and tubular lower and upper control arms.
    KYB AGX and Eibach Pro kit
    Bigger transmission fluid cooler and some other cooler.....
    The interior was redone completely - red and black leather racing front seats, leather rear seat, upholsered black leather door inserts, 2g Eclipse stitched steering wheel /no more crappy ebay wheel/.
    Exterior was changed a little - got new Evo 9 spoiler, sold the Evo 7 one
    Suspension - got rid of the pro kit and installed Ground Control coilover sleeves with QA1 springs 650lbs front ans 450lbs rear. Installed front and rear camber kits.
    Drivetrain - 5 spd swap was scheduled for December 7th 2008, and I have all the parts for it. It will be nothing special: 7g galant manual transmission, Exedy clutch, fidanza flywheel, SS clutch line.
    Powertrain - for an exception of the air filter, and header and exhaust, nothing was done, because it was still auto. I needed a few more parts to finish the parts list and go for the installation. It will be pretty basic blow thru setup - GM MAF w/ translator, 16G turbo, Bullseye hot side, Evo 3 O2 housing, 3'' downpipe, 2.5'' intercooler piping, 1g Eclipse BOV, Aeromotive FPR. It will be running 8-10 psi on stock motor.
    Started collecting parts for turbo build
    16G turbo with Road Race Eng. j-pipe.
    Misc. parts
    Bullseye hotside
    Evo 3 manifold, and Evo 3 O2 housing
    MAFT gen1 ver 1.6
    More parts for the turbo build
    Prothane motor mounts
    Fuel Rail adapters inlet and outlet
    Aeromotive FPR
    Summint racing high flow fuel filter -6AN
    Misc Gaskets
    Misc bolts
    Spark Plugs NGK BPR7ES
    Silicone Couplers
    Manual Boost Controller with quick bleed valve
    PLX wideband controller and Prosport A/F digital gauge
    Sold the Evo 9 intercooler, and got smaller 3'' core
    Dejon tool Intake pipe
    Fluidine Aluminum Radiator
    Dec 7th 2008
    Well, I was officially 5 spd swapped. It took 14 hours of non stop work of me and Bronxbomr . I think it went good, although we had a small problem with the master cylinder - it took only 6 hours to figure it out. Car was running, but I was having some issues with adjusting the clutch pedal. I think the master cylinder that i bought off Advanced auto parts wasnt not doing its job; I don't have pics of the work, but ill post some of finished job later
    Update:
    Some suspension and other parts
    2-point under brace
    Aluminum shiter cable bushings
    JDM head lights.
    The other project ive been working on this winter
    work in progress
    Some more interior updates:
    work in progress
    before priming
    Got some old style Konig rims - Konig Verdict actually and picked up 225/40/18 Kumho Ecsta AST
    Got rid of the wide open front bumper and bought another one in good shape
    A recent picture of the engine bay. Still trying to get rid of the fugly blue, but no time lately.
    Got rid of all the cruise control system and installed non-cruise cotrol throttle cable.
    MOre parts
    SS oil feed line
    Balance shaft eliminating kit
    -6AN Fuel endings
    Evo9 fuel pump
    Evo3 510cc Fuel Injectors
    Symborski shifting kit
    RRE J-pipe fitted with coupler
    Dejon Tool Intake pipe with new filter
    Rebuild 16g mated with the Bullseye housing
    Custom Blow off pipe
    2.5'' T-bolt clamps
    Rebuild 63mm TB with block off plate
    JDM power folding mirrors
    Evo9 Steering Wheel
    Red-out tail lights
    Summer 2009
    Getting ready for paint.
    The color will be Hot Rods Red
    Did some fuel support work . Painted the fuel rail and installed the 6AN fittings.
    I ported the intake manifold today it is 60mm now matching the 1g TB.
    Ported both sides of the Evo3 O2 housing to match the aluminum gasket.
    Finished
    Evo 3 510cc injectors are installed.
    Bolted the O2 housing
    Evo3 manifold is ready to go in.
    Finished.
    July 2009
    Got these babes.
    Waiting to get it aligned.
    In my driveway
    Hm, I have a lug nut missing
    8th Gen Spoiler
    August 2009
    I did some work these days. Replaced the factory water temp gauge with Prosport gauge. I needed to trim the rear of the cluster to accommodate the deep gauge /never seen such a deep gauge/. I made the temp sensor adapter which will be fitted in the lower thermostat hose. Welded 1 1/4'' exhaust pipe and M8 x 1.00 nut together. NOw I have give it a coat or two of high temp paint.
    Full Spread of Prosport Gauges - Digital AFR, OIl pressure , Oil Temp, Boost
    4 - point Ralliart under brace /Thanks John/
    Its gonna be fun.......
    The 2g oil pan went in today. Also replaced the intake manifold gasket
    Skrap replacing the intake manifold gasket
    Getting ready to get rid of the distributor and instal the coil packs
    what do you used to paint your car? i have tried to paint my hood. never turn out good :(
    04-02-2009
    Denver Colorado
    1,447
    Great progress on the car over time man, did a great job on the stuff!
    www.blackheartmotors.net
    12-17-2002
    Sherman Oaks, California
    4,304
    awesome set of pics, good work dude
    http://socallifestyle.com/
    1994 Galant GS 5spd
    04-25-2007
    727
    Fantastic MKO... You have been through so many spoilers :) I like a lot of the custom work you've don and can't wait to see how the gauge and turbo setup comes out.,..
    10-05-2008
    Grand Rapids Michigan
    1,141
    You are really digging in !
    Thanks guys!
    On other note, I got these babes and just ordered the rotors from R1 Concept, so sometimes next week Ill have the 4-piston calipers installed. The rotors are 12.4'' /314mm/ in diameter vs. Evo ones that are 12.6'' /320mm/. When finances allow Ill get the 2-piston Evo rear calipers with 10.8'' rotors
    Cut open the downpipe 18'' away from the turbo, so I can weld the wideband bung tomorrow
    04-25-2007
    727
    Where u get the caliper brackets?
    cut me up an extra set if there a diy :)
    ^ If youre interested, pm me
    Cant do much in the rain, and its supposed to rain thru the weekend.....
    At least got the wide band bung welded
    Good work, lots of pics... Keep it up!
    So I got the 510cc dialed in with the MAFT and i get something very odd - under acceleration in 3rd, 4th and 5th gear I get knock when the AFRs are in the 12-10.0s. i just dont get it. Right now the fuel pressure is set to 50 psi.
    I read an article about injector latencies and I think the ECU keeps the injectors open for too long since its set for 275cc.
    Any advice would be appreciated it.
    08-18-2004
    Charlotte, NC
    1,029
    How much boost you are running? Which DOHC head are you using? Your ecu is eprom, you can have it socket and run an Evo 3 maps.
    1994 GS FYI
    DSM/CSM Manuals
    no boost for now. just trying to get the MAFT dialed in with 510cc. I havent swapped the ECU yet, but that will be done very soon. As soon as im done with the GS ECU on SOHC head, Ill swap the 1g head with cyclone intake.
    Since I bought many gauges /I got a deal/, I needed to come up with a spot to place the important ones like AFR and Boost. So, I came up with this:
    Bronx NYC (reppin)
    3,489
    Looks good. I thought of that at one time but couldnt make up my mind on it.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Installed them today, but I havent powered them yet
    Those look badass! Great idea, very practical :)
    TGC Regular bmore303's Avatar
    03-11-2007
    Baltimore, MD
    773
    Hmm what's your compensation set to? For 275 to 510 it should be approx 46%
    RIP
    1995 7G 4G64 / 63T DOHC Turbo
    Part Out Coming Soon
    In search of 2G 3000GT VR4
    Daily driving
    Dat '08 Cobalt Coupe
    Yeah, its was something like that, but i put the stockies back in, cuz I was getting too much knock when throttle is past 50%. Ill wait till I put the turbo in, besides Kolio hooked me up with some 450cc blue tops and Ill start with them.
