Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 13 of 53 FirstFirst ... 39101112131415161723 ... LastLast
Showing results 241 to 260 of 1043
  1. #241
    Heres another option for the 7g radiator. You can get a t-stat top off 4g63 hyundai. They have some kind of sensor there that can be removed and plugged with brass screw in cap
  2. #242
    I got some custom decals made, but decided to install it after some 50 oz of coffee /not good idea/, now i have to order it again
  3. #243
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    2g radiators don't fit. The mounting tabs on the bottom are in the wrong spots. Galant radiators are wider by a couple inches.
  4. #244
    11-14-2007
    Boothwyn,PA
    719
    We know... Me and him are trying to figure out a way to fab it to work....
  5. #245
    09-06-2008
    533
    If you look closely you can see I used the T-stat housing off the 2.4 engine and used the Galant radiator. It was very tight where the CAS is. I had to do some grinding on the housing to get it to fit. I also needed to run a coolant line to the turbo though so that meant some funky stuff going on on the back side where the bolt goes in. The sensor screwed into the top is for triggering my fans (the 1g ECU I'm on can't run them).
  6. #246
    Quote Originally Posted by eclipsh View Post
    yea thats exactly what we did with mine made things a lot easier.
    1996 galant s
  7. #247
    22mm Addco rear sway bar went in today. The biggest bar a FWD DSM will ever see
  8. #248
    08-18-2004
    Charlotte, NC
    1,029
    I.Need.To.Get.One.
    1994 GS FYI
    DSM/CSM Manuals
  9. #249
  10. #250
    12-17-2002
    Sherman Oaks, California
    4,304
    ^^^^ OOHHHH DAMN! congrats dude!!
    http://socallifestyle.com/
    1994 Galant GS 5spd
  11. #251
    props man, but i'd be scared to even try running those on a street car.
    Make sure you have tip top tires man.
    With my RMDSM bar its the best I would ever want it to function. Its pretty scary when the rear end just kicks itself out on a hard turn down the side of a mountain. There is no warning lol. On a stock car you'll hear the tires squeal long before the traction breaks loose. With a big fatty bomb batty sway bar its pretty instant, one second you are hammering the turn, next second your butthole tightens up and you are trying to keep the car from being sideways in the middle of a turn. I speak from experience. Almost trashed the white car once or twice.
    They are fun at low speeds though. High speeds(anything above 45, sometimes less with the right curve) they can be a bit unpredictable. Just be careful man.
  12. #252
    12-17-2002
    4,304
    i can back that up, even with my 18mm which is like 3/4 of the thick fat dicks you guys are running, it's pretty stiff back there.....i can't even imagine driving with either of your guys' rear bars
    1994 Galant GS 5spd
  13. #253
    this is true, i almost wrecked mine in the winter. on second taking the turn fine the next i was sidways. as a result my drivers side of the car now sits lower
    good shit chris. what are the specs on the pistons?
  14. #254
    stock bore, 9.0:1 cr
  15. #255
    02-18-2009
    NEWBURGH, NEW YORK
    486
    the 7 g is coming along . congrats mko . its looking good
  16. #256
    ohhhh very nice
  17. #257
    IDK, what do you guys think? Emblem or no emblem.
    I kind of wanted a smaller one but thats what i got. Old style red emblem, just dont like the chrome trimming
  18. #258
    Emblem looks fine, I like it. Not a fan of the orange reverse lamps.
  19. #259
    The idea was to have the entire bottom part of both tails as a giant turn signal and have the reverse lights separate somewhere lower on the bumper
  20. #260
    OIC. Couldn't just get amber bulbs? Or were you going to put 50w 1156 bulbs in there and have it be really bright?
