Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 43 of 53 FirstFirst ... 33394041424344454647 ... LastLast
Showing results 841 to 860 of 1043
  1. #841
    It will be a DD brah, I want it to be as quiet as possible.
  2. #842
    Nice. Glad to see pieces of it still seeing action.
    Wish he hadn't lost the Vibrant dual outlet muffler that was on my old GS. That was best muffler ever for OEM look and remaining quiet and refined without sacrificing flow.
  3. #843
    IDK i must be stupid or something, but I cant install the pump assembly.
  4. #844
    08-18-2004
    Charlotte, NC
    1,029
    Is it the right size gasket?
    1994 GS FYI
    DSM/CSM Manuals
  5. #845
    I got it with it bro.
  6. #846
    Sorry I am not much help on it just didn't have to go through that I just left my pump in the tank and bolted the whole assembly up. I would be willing to take my pump out and snap some pics if you think it will help. It's the least I can do as you have helped me along the way.
    7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
    7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
    3g 00 eclipse gt 3.0 at
  7. #847
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Do the basic check. Take the gasket off and see if the pump assembly drops in. After that, put the rubber gasket in place on the gas tank then lube up the pump cover and push it into the gasket. Otherwise you can leave the gasket on the pump assembly, lube it up, push it in as far as you can and then use the nut to pull it the rest of the way down.
    You could also try having the gasket half way on/in each and then pressing in.
  8. #848
    Might want to wipe it dry and try just vaseline, I have had great luck with that on injectors and other stubborn seals when all else failed.
  9. #849
    Thanks guys. I appreciate the advices. Still didnt have time to work on the fuel pump.
    So i have good and bad news.
    Good news are that exhaust is finished with a little exception of the WG dump to the DP. Also I have compression on all four cylinders.All lights work at the rear of the car, dash illumination works.
    Bad news is that I dont have any lights working inside the instrument cluster (CEL, brake, alt)....nothing. The MPI isnt clicking at all.....its kind of disappointing .
    I did hack the wires to the airbag module and still have to insulate them. I also hacked the wiring to the ABS ECU, and I wonder if that ECU just uses reference signals to it or actually there are wiring going thru to other components.
  10. #850
    Dash is coming out tomorrow. I might have done some wrong with the main power distribution block above the fuse box.
  11. #851
    your not keeping the ABS?
    the abs system is completely independent of the main harness in the car. it has it's own harness and sub harnesses. i think only a few wires link to the cluster. i know because i was gutting a 7G to add abs to my car .
  12. #852
    Well That was what i also thought, but its not. The ABS harness is a part of the dashboard harness.
    No bro, no ABS for me. It had to go.
  13. #853
    Pics of the progress.
  14. #854
    i don't know how many wires are tied into it, but i don't think it's that many. do you have the wiring diagrams for under the dash?
  15. #855
    i do have the diagrams, but im very anxious to start the car. Im just gonna cap the wires and take care of the more serious electrical problems.
  16. #856
    ^^ you gonna do a "first start" vid or us? :DDD
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  17. #857
    Sure bud.
    More progress
  18. #858
    04-25-2007
    727
    Exhaust looks a bit low in pics. The true test is the random speed bump that shows up while driving.
    The fuel pump was a hassle for me as well, I purchased a new gasket and used some vaseline, when installing. It must be tight or gas will leak through it which makes the install difficult. I got it installed god though and don't have any leaks back there, also reused gas carbon box from original 7g setup. Got to pay close attention to feed, return and relief filter gas lines.
  19. #859
    Welded the dump tube to the DP, got it painted and wrapped.
    She is a pretty and she is a mine.
    New bumper...........
  20. #860
    That mine?
