nice bumper. that damn ground issue seems to be a headache.
God man been so focused on the green G I forgot how good the red looks haha. You have no Idea how incredibly jealous I am. Looking forward to seeing some more updates!!
... also if you ever HAVE to to just want to get rid of some of them parts.... I'll be the first to pick up anything and everything you have, God forbid anything to happen to those beutiful 7g's though
1994 Galant GS - Daily driver
1994 Galant LS - Parts car
Garage: http://www.thegalantcenter.org/garag...iew-20241.html
unffff car sounds LEGIT!
hmmm that electrical problem sounds like fun :(
sure the harness was in good condition and there arent any broken wires?
The "Tumbler" Is HereStock Longblock/Stock PCM | Custom Garrett 50-1 | 17 Psi | Weighing 2xxxLbs3xxWHP/3xxWTQ [Current]
Yeah harness was stock and unhacked when i pulled it out and started working on it. hopefully i'll fix it in no time.
MKO. You doing Great. Keep it up. Hope i could see it at MOD. I will recommend to get some type of IAC, dont know much about the old ECU how they handle cold start. I'm saying at cold start you need 2K rpm so it could get you some fuel and help warm up the engine. This helps vent the crank case better. Is for a reason some car idle high at cold start.
Lookin good man
91 Galant VR4 -Samara- #550/2000
You are missing a grounding point. What harness are you using again?
1994 GS FYI
DSM/CSM Manuals
Thanks for the advices guys!
its the stock GS harness and stock ECU/SAFC for now just to get it running.
Nick, jump in and save me from the fuel sending unit wiring nightmare!
I kept pretty good notes on all my wiring including the two sensor tank rewire and the gauge is spot on . Let me know if you need any of that.
7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
3g 00 eclipse gt 3.0 at
yes sir, please do share.
I spliced the wires between the plug at door threshold and before it drops to tank.
Galant GS Eclipse GSX
yellow/white yellow
small black small black
yellow/blue small yellow/blue
black/blue black/blue
large black large black
I lost my notes so I just quickly pulled up the seat to check I abandoned the 3 press sensor wires and grey/red, yellow red, grey/blue and large yellow blue.
im pretty sure i wired it the same way , but i only put 10 bucks worth of 93 octane in there. Or maybe the ground wire isnt doing its job since i have the ground problem.
Thanks bud. I'll investigate more.
SO I found the ground problem - the ECU has 3 fried circuits. I'll attempt to repair it tonight and hopefully it will be running right next time I go over to the garage.
Ain't that a bitch..
1994 GS FYI
DSM/CSM Manuals
Freakin mitsus
Whats the word?
And I drove it for the first time!
Say whaaaaaat? Sooo how was it?
