Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 48 of 53 FirstFirst ... 38444546474849505152 ... LastLast
Showing results 941 to 960 of 1043
  1. #941
  2. #942
    Please tell me the red seats are gonna go
  3. #943
    Oh yes as soon as find stock seats in good condition. I dont like them at all, but thats what i have at the moment.
  4. #944
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Check out stock seats from other cars too. I've been very happy with my 90's Celica seats. Much better support for canyon carving. I've also got 2000 or so Celica seats in my '89 4Runner. Side bolstering isn't as good for a skinny guy but for someone bigger they'd be more comfortable. They did take some fabrication to install though. Other ones I've eyeballed are RX8, Evo, WRX. All factory seats so they're built well and comfortable for long hauls.
  5. #945
    The green G came home for the first time tonight.
  6. #946
    Well I have bad news. Pulled the spark plugs today and all of them had oil. There was oil on top of piston dishes too.
    I think I might have toasted the valve seals.
    Another project ahead of me.
  7. #947
    NOOOOOOOOOOOOOOOOO I finally get my 7g running again and the 7g I inspire to be goes down!!!
    Man I hope its just the valve seals, Good luck man and keep us updated!
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  8. #948
    12-13-2010
    Brooklyn, Maryland
    4,643
    One car gets up and going, the other one goes down. Life of a Mitsu tuner I guess..good luck in solving the problem Chris.
    -Greg
  9. #949
    I believe it's the awd that went down.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  10. #950
    12-13-2010
    Brooklyn, Maryland
    4,643
    Oh, well that sucks even more because he just got it running.
    -Greg
  11. #951
    i dont have heat, but the heater hoses are hot. Im thinking the blender is damaged. Any other opinions?
    From the service manual: (I dont understand how vacuum goes to heater)
    Low Coolant Level
    Incorrect thermostat.
    Restricted coolant flow through heater core.
    Heater hoses plugged.
    Misadjusted control cable.
    Sticking heater control valve.
    Vacuum hose leaking.
    Vacuum hose blocked.
    Vacuum motors inoperative.
    Blocked air inlet.
    Inoperative heater blower motor.
    Oil residue on heater core fins.
    Dirt on heater core fins.
  12. #952
    If it is hot on both in and out then the problem is flow, it is probably partially plugged internally. This is what I do just disconnect both core lines so isolating the heater core, flush with water, plug one hose and pour polyzag directly into the other until full then let it sit for just a couple minutes and then flush with water in both directions. It is acidic so don't leave it in for more than 2-3 minutes, be careful use gloves and glasses and you may want to get some longer hoses so you can add and flush outside that sweet engine bay.
    7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
    7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
    3g 00 eclipse gt 3.0 at
  13. #953
    I somehow managed to strip all teeth of the flywheel ring gear, so as of today my green Galant is down.
    I knew the red Galant had skipped timing, so I did a timing belt job in a gas station parking lot in 20 degree weather with wind chill. She's up and running and boy did I miss her. I forgot how quick the red G was.
  14. #954
    Man that sucks about the GS, what kind of flywheel was it? Did it cause any damages, or is the flywheel the only casualty?
    Also sucks about having to do the timing job where you did lol but at least it wasn't damaged!
  15. #955
    it was a brand new fidanza flywheel. Thats why I dont understand how. If I bought it used then OK I can accept it, but damn it only has 5k miles on it
  16. #956
    Arent those replaceable though?
    Sent from my DROID RAZR using Tapatalk
  17. #957
    they are, its just the work I dont have time and place to do
  18. #958
    oh wow! how in the heck does that happen? and i bet you got a lot of stares at the gas station haha
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  19. #959
    that sucks i have a fidanza with less than 5k in mine... that makes me nervous...
  20. #960
    ^youll be fine, I had no issues with mine
