Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 5 of 53 FirstFirst 12345678915 ... LastLast
Showing results 81 to 100 of 1043
  1. #81
    just shut it hard then huh?
  2. #82
    Ok guys, Pictures thruout the thread are dead. Theyll be back on the 6th. Meanwhile, ill be posting thru my new Photobucket account
  3. #83
    It took about 3 hours of work today - put everything together. Im happy with the results.
    The marks do not match at relaxed position. I wonder why?
    Final result
  4. #84
    the exhaust cam roles like 10 degrees off, if i remember right because of the valve spring on I think the #3 cylinder...
  5. #85
    once you set the timing, the marks will line up fine. The fact that they don't line up is a good thing. Makes it easier to set the timing. That's why yiu put the belt on a 1/2 tooth off. Once its tensioned the belt draws the marks together.
  6. #86
    You mean half a tooth the way it is now, or I have to turn the exhaust cam half a tooth past the intake mark to the right
  7. #87
    i recommend once you get the head on and the timing set, rotate the engine a couple time and check the torque on the cam cap bolts. you will be suppressed when you do.
    1996 galant s
  8. #88
    Yeah, i was gonna do that since im reusing the old bolts. If they were new the torque spec is 14-16 lbs
  9. #89
    yea even if they where know i would still recommend it just because of the spring tension on the cams, i checked mine and a couple where loose had to re torque them.
    1996 galant s
  10. #90
    If you start from the caps in the middle and work your way out, by the time you get the most outer ones, the middle ones will become loose. I went over all of them like 3 times, they should be good
  11. #91
  12. #92
    Now do a 15psi pull please.
    1996 galant s
  13. #93
    04-25-2007
    727
    nice pull :) wsuip with ur inter cooler did you paint it black? side mount?
  14. #94
    yeah its flat black and its a fmic
  15. #95
    Flat black fmic ftw son!
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
  16. #96
    IDK what is wrong with this car. Now I cant boost much. It goes to 2 psi max. I even bypassed the MBC and ran the line from the j-pipe to wastegate and still the same. My girlfriend filled me up with 87 while I was paying inside the gas station, I hope this is why i cant boost.
    I still have the hiccup and it gets no better. Ive tried everything possible. My AFRs are normal, but my spark plugs are white. It acts like a post MAS leak, but Ive checked it all.
    Im about to put my stock MAS and just run the SAFC.
    Im open to any suggestions
  17. #97
    hot side crack?
  18. #98
    found this for you if your interested....
    http://www.ksl.com/index.php?nid=443...iew&ad=1818712
    runs great and has new clutch. IT IS A GS. CALLED AND VERIFYED. Is willing to take 650.
    1994 Galant S. 90 Percent GS.
  19. #99
    trying to understand what the seller is trying to say is brutal.
    Jigz-TGCIL Sosick Motorsports
  20. #100
    ya, he doesnt know how to type english well but he speaks if pretty well
