Thread: How to turbocharge your 4g64 8g
Page 3 of 3 FirstFirst 123
Showing results 41 to 42 of 42
  1. #41
    I've been using the regular height k&n and Mobil1 filters with my sandwich plate. My car is pretty low for NYC and I've never had it hit the oil filter.
    Is that you Edgar?
    Yes sir
  2. #42
    hellaflushgalant
    i have been thinking of booting my 8g 4g64 galant. Everything is stock but the motor is very healthy, Will i need bigger injectors if i run only 9psi of boost? Also will i need a separate ecu to run it for will my stock be ok? plug will this turbo be too big to never spool?
    http://www.ebay.com/itm/T3-T4-TURBO-...9133c6&vxp=mtr
    Thanks, Any help is greatly appreciated
