Thread: big 6g7x IM
Showing results 1 to 20 of 31
    08-18-2004
    Charlotte, NC
    1,029
    big 6g7x IM
    Found this...
    1994 GS FYI
    DSM/CSM Manuals
    05-03-2007
    Socal/Central Coast
    3,803
    hollllly sh*t. That actual opens up a lot of room on the rear valve cover, and allows for simple maintenance like changing the spark plugs without having to remove the damn IM
    Damn... it's facing the wrong way. Anyway, where did you find that!?!?
    05-03-2007
    Socal/Central Coast
    3,803
    should be pretty easy to manufacture facing the right way for us I assume. Just gotta flip the bottom plate that connects to the lower plenum, and then flip the whole unit.. then again I don't know what the bottom of it looks like. If its not perfectly symmetrical, then this is not feasable lol
    uh, you guys realize the pic was taken from the back side of the engine (notice the oil cap is missing indicates rear valve cover)
    05-03-2007
    Socal/Central Coast
    3,803
    we did. and the manifold is still facing the wrong way
    maybe it's designed for different setup than what we're accustomed to.
    04-02-2009
    Denver Colorado
    1,447
    Most likely something for a 3000GT perhaps...
    www.blackheartmotors.net
    deff from a 3kgt, I think that topic is on 3si.org if im not mistaken
    02 Diamante VRX 5spd swapped
    90 Galant GSX 5spd EvoSpec 4G63 swapped
    01 Sebring GT Coupe (6G75 Powered)(sold)
    08-18-2004
    Charlotte, NC
    1,029
    it's for a Magna(Diamante)...
    1994 GS FYI
    DSM/CSM Manuals
    04-02-2009
    Denver Colorado
    1,447
    So...why are they facing the intake feed to the passenger side?
    maybe he has some sort of forced induction setup and the piping would be more efficient if it was on the other side?
    05-03-2007
    Socal/Central Coast
    3,803
    yea I was gonng say it can't be for a 3000gt because the engine would not have been positioned correctly. The timing belt needs to be on the other side correct?
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by pinoyesv6 View Post
    Yea, you can see the intercooler (atleast I believe that's what it is), on the second picture, no way you would get good efficiency N/a with that kind of intake design so it's clearly an FI setup. It's a good design though if they are running a turbo on the rear to keep things a little cleaner looking.
    I totally spaced that lol...
    wow I totally thought that was a custom 3kgt sohc engine lol
    My exact thoughts!
    If you notice between the power steering reservoir and the headlight there is an opening cut most likely for the IC piping to reach the IM using about 1/5 the distance of standard pipe routing.
    08-04-2004
    Westchester NY
    1,332
    thats TJ's new setup
    Baltimore, MD
    2,848
    Quote Originally Posted by ZigenScarface View Post
    Can't you let the dead rest in peace, please?
    Chip
    (Paint Code: Porsche LC9Z)
    i have thought of something just like that a year or two ago. would free up some power just in n/a too.
    Member since October '03
    05-03-2007
    Socal/Central Coast
    3,803
    hmmm I'm still wondering how it bolts to the lower manifold.. of maybe it's welded to it
