Dodgy wiring between the master controller plug and the window?
since I got my 7G a couple years back I have had an issue with the front passenger side window. From the master control I can open it, but can't close it, from the passenger side control it will go both up and down. I tried to replace the master controller, and same issue. Any other ideas?
T.I.A.
Jason
JayDee,
Did you find the solution to this issue? I have the same prob, but that is minor compared to what I have right now. Check my post in car probs
later...
have you changed the window motor? Im sure its just a problem somewhere along the lines of the switch. I had that problem at one point and when I took it to get it fixed they said it was a short somewhere on the board.
Drive It Like You Stole It!
7G Erubini Body Kit for sale
Id say the door connectors behind pass. and drivers side fenders get corroded. I have the same problem every once in a while usually when cold
i had the same problem before, i dont know if it is common on these cars.
what i did was i took out the master windows switch and took it apart. you will find the a rubber piece under the button. and clean the contact point on the circuit board with light sanding. That is the the good situation. Some time the switch burn out but you will see burnt mark.
