Thread: All Spark Plugs are wet in oil
Showing results 1 to 9 of 9
    NEWBIE LoneWolf's Avatar
    09-19-2009
    Manila, Philippines
    37
    Icon9 All Spark Plugs are wet in oil
    Hi everyone.
    I'm a new car owner, and would like to ask what I need to check and have repaired in order to correct my spark plugs (all of them) being wet in oil.
    Here are some specifics:
    Ride: 1996 Mitsubishi Galant S (the 4-cylinder one)
    Mileage: 83,000+ kms
    Last Change of Spark Plugs: 08/06/09 (82,843 kms)
    Last Oil Change: 08/06/09 (82,843 kms)
    Discovered when: During engine wash yesterday
    Hope you can help me, thanks everyone!
    "There isn't one of us that doesn't want to be someplace else.. But this is what we do, who we are.." - John J. Rambo (Rambo IV)
    Ur head gasket maybe?
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    valve stem seals, head gasket, cracked head/block or piston rings. More than likely its head gasket or valve stem seals.
    i agree with shadow19, usually its the valve stem seals
    09-19-2009
    Manila, Philippines
    37
    Thanks guys, I will have both the Valve Stem seals and Head Gasket checked. :)
    12-17-2004
    Louisville, KY
    4,328
    is the oil on the top of the plug? you know, the side thats NOT in the combustion chanber. the side where the spark plug wires connect to?
    or is the oil on the electrode itself?
    I demand pictures
    10-18-2007
    Glen Burnie, MD
    1,314
    Spark plug tube seals
    Usually its the head gaskets that goes first.
    is it wet when you pull it out and oil in the spark plug tube too ? because oil on the plug tip would be really big problem, but if you pull the spark plug tube out and there is oil that is simple valve cover gasket set.
