Thread: 7g vr4 evo build
Page 4 of 4 FirstFirst 1234
Showing results 61 to 69 of 69
  1. #61
    Yeah i'm pretty pissed about the oil seal, hopefully shouldn't be too expensive to fix, and atleast thanks to the power it's making it's a pretty good sign that it's not the rings causing excessive blow by
  2. #62
    The guys pulled it apart today, and looks like it didn't spit the crank seal, it munched the oil pump instead, I've been told it's a common fault of the HKS cam belts, what they do is pull too hard against the oil pump and cause it to wear out the housing and dumo out the oil, he was saying he's seen it happen to quite a few evo's even a evo 9.
    So it's gonna be a new ( second hand ) front case and oil pump and a genuine miti cam belt and it'll be back on the road
    Just a word of advice to any running a HKS cam belt, you might want to think about replacing it or the same thing may happen to you
  3. #63
    Just got it back, heres a copy of the dyno sheet
    332kw@6500 and 511nm@5600
  4. #64
    Well I found myself on a quiet road with a camera this morning :-o
    http://www.youtube.com/watch?v=larbzEy2z9Y
    http://www.youtube.com/watch?v=mlgq9kZHrwU
  5. #65
    440whp not bad
    1996 galant s
  6. #66
    Got the breathers done at work today, turned out allright, it was going to be to much hassle to put them in the side of the cover so I just stuck them in the top, stoked cause the bonnet closes :-o
  7. #67
    Quote Originally Posted by 7gvr4 View Post
    your turbo is surging hardcore.
    I can hear it clear as day in the second video. Thats no good that or there is something wrong with your bov.
  8. #68
    Yeah i'm pretty sure that was because the boost controller was having issues adjusting the duty cycle for the new boost levels, pretty sure it's sorted itself out now and is holding steady at 1.55 bar
    Those runs were done at over 30 psi or 2 bar!
  9. #69
    Just got back from the 4 and rotary nats which is the biggest car show in NZ, if anyone is interested i'll post all the pics i got from the show in a new thread, for now though heres a few of my car from the club stand
