no not at all just clean the surface so that a good ground connection is made. but you are all good no problems, you Can actually Mount it any where.
so as I was swapping the Throttle bodies, I discovered that the bolt that the aftermarket intake mounts to broke and saw what it seems like a ground wire and a sensor dangling. I found another free bolt so I bolted it down to that instead. My question is would this cause a problem as the location is different?
Here is a pic of where it is now.
it used to be where the intake mount is.
Your signature is against the rules too - Prophet
