Thread: Problem starting car
Showing results 1 to 2 of 2
    Mr SpiLLz
    This morning i went to start the car but it would not start.. Nothing worked,not the lights, radio, locks nothing.. So i try to boost it, it does not work... Although it almost did, but it would not turn over... So i bring the battery to autozone it gets charged i bring it home, put it in.. Now everything works, the lights, radio, locks... Although they work slighty weaker then normal, they do work.. But i still cant turn the car over... What can be the problem?
    I think it might have something to do with the other day when i had to back out of my street in the snow because they were going to plow... When i did it stalled like 4 times before i parked, can that be it or what? thanks...
    could be a lotta things.
    it sounds like no alternator output. Is the belt on it? is the master fuse blown? is it attached correctly? has it failed?
