Thread: Wheel help
Showing results 1 to 5 of 5
    Wheel help
    My 8g world spec currently has 15inch oem alloys with 195/65/15 tyres. I have been offered a set of Tenzo R alloys very cheap but they are 17inch. Does anyone know if these can be fitted to my G without any mods, or if not what sort of problems could they cause?
    4,455
    as long as they are the same bolt pattern you should be pretty much good to go. pending you aren't dropped too low and they aren't too wide
    Jason - - cofounder of TGCNY
    2001 Galant ES
    Quote Originally Posted by mrjaydeeone View Post
    Thanks Jay. No I am not dropped, in fact very few cars over here are dropped because very few of our roads would be up to your highway quality. I will have to check the width with him.
    4,455
    Quote Originally Posted by kildaremike View Post
    you got it. Also the offset you might need to check out too. They might stick out too far, and you wouldn't want that either.
    2001 Galant ES
    If they came off an Evo then they will fit no problem. I have 17'' EVO 8 MR wheels on mine. Running 225/45/17 tyres
    Mike
