Thread: Installing Basslink 2
Showing results 1 to 2 of 2
    02-07-2007
    ORLANDO
    1,599
    Hey fellas have any of you hooked it up to the stock system/non infinity if so how?
    i'm doing it myself so wiring is pretty cake to me..All I know is that i'm wiring the rear speakers to it..
    what am i gonna need?
    thanks for tha help..
    Fort Worth, TX
    1,418
    If you are getting the infinity baselink you should get everything except the power line which you have to buy and connect to your battery. If you are connecting to stock system you will be using the line to your current speaker to get the signal it comes with that kit. i have an aftermarket radio so I had bass RCA output and did not need to use the volume control which you will need to use if you use your speaker lines.
