Thread: Where can i get a front strut brace?
Showing results 1 to 5 of 5
    Does the one from the 4g eclipse fit? if not where can i get one? thanks.
    Your signature is against the rules too - Prophet
    4G eclipse should fit, same chassis. That or the 9G RalliArt Galant should have one too.
    tanabe makes a lower front brace for our cars... direct bolt on. U can get a upper bar from a gts or RA, or the adj tanabe for the 4g. Not sure if the cusco brace will work though...
    uhhhh...... Whats a 9g???
    got one deliverd, a off brand we'll see it was cheap and so fAr it's doing it's job. but thanks.
    Quote Originally Posted by rr2swift View Post
    where did you get it from, ive been looking for one not too expensive
