Thermostat stuck closed is the simplest thing to fix, and Id suggest you start form there
Water maybe cools the engine better but it builds deposits in the radiator causing possible clogs. Just hope you didint damage the head /warped/ when you overheat, cuz the head gasket wont be able to seal and will introduce air into the system, making it impossible for the water pump to operate.
