Thread: 6G72 swap question...
Page 2 of 2 FirstFirst 12
Showing results 21 to 34 of 34
  1. #21
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    http://www.youtube.com/watch?v=YmKHTov-DV8[/URL] Click on this link to see but i was recently advised not to do the swap because u would need a whole new wiring harness & the ecu for the 3.5 so ur car can pass inspection
  2. #22
    thats a 4g74 in that g Aka Diamante
  3. #23
    11-18-2009
    Buffalo, NY
    1,758
    Quote Originally Posted by deeznutz View Post
    its a 6G74 also checc this out http://www.youtube.com/watch?v=7FxCPXtVuBk
  4. #24
    TGC Regular stvn_mj's Avatar
    07-30-2008
    Avondale, Arizona
    961
    ^Thats a former members' galant.
  5. #25
    11-18-2009
    Buffalo, NY
    1,758
    Quote Originally Posted by stvn_mj View Post
    ReallY? WoW
  6. #26
    blue8g
    yep stvn's got it........that's a 6g74........it's pretty nicely built if i remember
    boostzealot.......
  7. #27
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by blue8g View Post
    boostzealot.......
    boost has a heavier build being done now though...it will be even more powerful and impressive than the 3.5 he built.
    As for passing emissions and wiring harness and all that...the 3.5 is a DIRECT drop in replacement enginethat only differs in the displacement. You can run it off the stock ECU and stay with the 6g72 injectors without having to tune anything. If you use the 6g74 injectors than you will run extremely rich off the stock 6g72 ECU and then will need to tune or emission testing will be a fail.
    3G Eclipse Performance & Development - Denver, Colorado
    www.blackheartmotors.net
  8. #28
    05-03-2007
    Socal/Central Coast
    3,803
    ^^correct
    TECHNICALLY, the engine swap is ILLEGAL, because you can swap to a newer engine *made for the same car*, but seeing as how the Diamante is NOT the same car as the Galant (obviously), and the displacement is larger, it is illegal.
    However, I passed emissions solely on the fact that they couldn't even tell the difference between the two engines. They look exactly the same when you look under the hood briefly. Oh and I am untuned using 6g72 injectors
  9. #29
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by beam514 View Post
    ^^correct
    You can actually get by the illegal portion due to the newer engine build dates. They are considered to be more "efficient" and most state inspection places may ask about an engine swap, if the year of the vehicle the engine was pulled out of is older than your car's manufactured date then it's a problem, if the engine is newer you are practically free and clear provided it passes the emission testing.
    its not so much as the same make and model of the car, but more that it is from the same manufacturer.
  10. #30
    05-03-2007
    Socal/Central Coast
    3,803
    Quote Originally Posted by SPD_FRK View Post
    hmm I guess there is some flexibility with the law. I wasn't going to go blatantly saying I did an engine swap though :) I'm wondering is California laws are more specific about it though?
    For example, would swapping in an STI engine w/ turbo into a normal Impreza be legal?
  11. #31
    04-02-2009
    Denver Colorado
    1,447
    There are A LOT of loop holes in the laws, just ave to find them ;)
    I would imagine California would be the same when you still consider as long as the engine is from a newer vehicle with better EPA standards than the original equipment. California is always a tricky state though, but I would bet it would still fly through an emission test with a pass, if not better test results than the original engine depending which engine is swapped in.
    The 6g74 hasn't really had much update over the 72, with the exception of the fuel injectors (which we know would cause rich condition on our ECU w/o tune, and ultimately a fail on emissions). So really, running your stock 6g72 injectors and ECU, on a 6g74 would probably run lean (something auto makers have been doing to vehicles for a long time now to reduce emissions anyways).
    You could easily do that type of swap, it wouldn't be any different than taking in a OEM made N/a vehicle with an aftemarket turbo installed, as long as it can pass the emission testing in the specific state. You are smart to not open up and say right away it had an engine swap. If they don't ask, don't tell. If they do ask, make sure you have whatever information they may ask for.
    I know for a fact that out here we have passed numerous inspections and emission testings with some of our diesel trucks (different testing yes), but these were Ford trucks with a Dodge Cummins swapped engine hehe
  12. #32
    blue8g
    boost is doin more stuff? where'd you find this? i just pm'd him on evom........and i found TJ on evom too lol he's got neon green wheels ............they're dope
  13. #33
    Experienced TGC Member johnygezony's Avatar
    10-05-2008
    Grand Rapids Michigan
    1,141
    neon green....
  14. #34
    04-02-2009
    Denver Colorado
    1,447
    Yea he is doing more stuff...I have connections lol.
    Tj....pfft
