Thread: Car wont start, whinning noise
Showing results 1 to 11 of 11
    ok so i drove ma car like half a mile to the gas station, went inside and when I tried start it up it started for a few seconds put it in reverse and she cut off.I tried starting it and it just makes this whinning noise, no clicks just whinning. I'm thinking its the starter but i'm not really sure. My timing belt is ok got that changed like at 120k and have 150k rite now. I neva changed the starter so its probably the original one, anyone had this happen
    we rip what we sow
    Bronx NYC (reppin)
    3,489
    whining noise is timing belt and bent valves
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    Check your other belts to make sure that they arent to loose and are slipping and whinning, mine used to and it was real annoying, i just replaced them and the problem went away.
    08-04-2003
    NY
    4,344
    Quote Originally Posted by bronxbombr View Post
    how can it be the timing belt and bent valves if the car wont start and the belt is good? Its not whining while running, its whining while attempting to start.
    If its not clicking and just whines it could be the starter is just shot. Try tapping on the starter a few times with a hammer and try starting it again. Did you physically remove the timing cover to make sure the belt was OK or are you just assuming its OK since it was replaced fairly recently?
    99' Galant ES
    4G64/63T
    AEM EMS
    I would check the belt anyway. Did you replace any of the other belts? Cuz it is possible that if one of the belts have snapped, it might've taken the timing belt with it and that would be REAL bad.
    Although, it sounds like the starter might be dead. Only thing is, why would it start and die once he puts it in reverse?
    Jigz-TGCIL Sosick Motorsports
    Maybe it died in reverse because of the RPMs dropping because it was under load. did it die in any other gear? or only reverse?
    i was backing out and it just cut off...I friend of mine tried to move cam shaft to see if the motor was locked and it hadly moved. I dont know how easy its supposed to move Im gonna get the starter tested sat, hopefully its the starter
    we rip what we sow
    08-04-2003
    NY
    4,344
    Quote Originally Posted by bigc View Post
    it aint supposed to move that easily, you shouldnt be able to move it without a wrench on the bolt and FYI you should never try to move it like that as you can cause it to skip a tooth or damage something. Always turn it the correct way by using a 1/2" drive extension and ratchet on the crank pulley. there is a little square cutout in the splash shield behind the passenger front wheel you pop that out and put the extension thru and into the crank pulley.
    99' Galant ES
    4G64/63T
    AEM EMS
    Bronx NYC (reppin)
    3,489
    im telling you its the timing belt. Been there done that!!!!!!!
    04-02-2009
    Denver Colorado
    1,447
    When you are cranking the engine do you see any rotation on the crank pulley??
    If you see rotation on the pulley then you have another issue such as timing belt may have jumped teeth and caused timing to be off, or damage to the valves/head. Check the compression on the cylinders, and also make sure you are getting spark to all cylinders.
    If your crank pulley does not rotate when you are cranking the engine, then the starter is junk and not engaging the ring gear to crank the engine over...something which also makes a "whinnning" type noise.
    www.blackheartmotors.net
    maxrezn
    I just got rid of the same exact problem yesterday. The accessory belt was loose and needed more tension. Took 5 minutes for my mechanic to fix.
